Finally done mine. Holy cow I didn't expect it to work this good. It's so cold in the cab that I think I froze my ***** off. One of the most bang for the buck mods I've done.......
__________________
Early 99 F250 7.3 4x4 Lariat LB SD - DP Tuner, CCV, V10 tranny cooler, 6637, TC lock switch, bunch of LED's, HID headlights, rear/front camera's, Pioneer AVIC-D1 GPS, Oil Guard Bypass, SS HPX, turbo back 4" SS exhaust into Heavy Parts International stacks, Autometer gauges, Zoodad, air horns, new stock chrome wheels...
here its either hoootttttt or cold, so manual would not be a problem, but if I have to spend $12- $15 on parts, I would just go with nlemrise's parts list and just spend the $20! you know.......
I get your point and where I live it is also either HOT!! or cold. So this was just a really easy inexpensive way to see if it would really make a difference. and it sure did!! You can't have cold enough A/C where I live!! And another plus is it just cools the cab so much quicker.
Don't know if I'll go ahead and order the DS kit or not but for now I'm just gonna see how the manual valve works out. If it becomes a PITA once Temps cool down then the DS kit gets ordered.
JB
__________________
2003 F-250 CC FX4 Lariat 4X4, 6.0L, SCT tuned by John Wood, AFE intake, 4" TB W/5.0" RBP SS Tip, Fumoto, 8 inch Edge lift. 37x13.50R-18 TOYO M/T's on 18X9 Centerlines, Dual Fox's w/Res. w/ Fox steering damper, singles in back...
i just put the Dieselsite kit in, 20 min, and done, i havent tested it yet , but will next saturday, on my way to BTS
__________________
2005 F350 KR dually
SCT X3 with Spartan tunes,Magnaflow SS duals with 5" AFE tips.Headstuds in the box. Where did the EGR go? It was there yesterday
2002 VW Jetta TDI stock - 53.3mpg
An old trick to help keep an engine from overheating is to turn on the heater. I guess the heater core acts as another radiator. My wifes Explorer started to overheat just the other day. Needle was almost to the H before we noticed. Switched on the heater and the guage dropped back to mid range. Still not sure why it started to overheat since it hasn't done it since. Thermostate, or needs flushing maybe? Mind you, turning the heat on when its already almost 90 degrees make things a bit miserable. Anyway, I like the tie in to the A/C controls for this reason. That is, being able to route the collant to the heater core on the fly.
__________________
Doug
early 99F250 PSD 7.3L 4x4
Heavy Duty TC, ISSPRO gauges on the A-Pillar, AC improvement mod, True Cool. CAT delete, Harpoon and Hutch mods with prefilter
The DieselSite kit only shuts the flow of coolant off to the heater core when MAX A/C is selected. If you use any other position the coolant still goes to the heater core. That way you can still try that overheating trick if you had to but I seriously doubt that it would have any effect on our trucks if they were overheating. Too much coolant, too big a motor and too little a heater core.
__________________
Scott
'02 F-250 SC SB 7.3L 4x4 w/ 4" SuperLift, 315/75 R16 Toyo Open Country M/Ts, Bilstein 5100s - 6 position DI tuner, AFE Stage II w/Dry S Pro, HPX, 203* Billet, CCV, Sonnax, Tru-Cool, Fumoto, ZooDad, Brite-Box, 4" MagnaFlow SST, ITP OBA, A/C comfort mod!, Autometer Z series gauges, Scan Gauge II, Tough Country bumpers
You're gonna love it. Yesterday we were at the lake (98* with 80% humidity) and when I went to pluck the jet skis out of the water to go home I backed the truck down the ramp, set the high idle on and switched to Max A/C and then set it in park while I winched the skis up on to the trailer. By the time I got back in it was nice and cool and before we left the marina it was blowing so cold that the kids were complaining that it was too cold. I explained that in Texas there is no such thing as "too cold" or "too much A/C".
__________________
Scott
Some like white line some like red. Some guys get different results depending on year,
factory setups etc. Now that Im not sure exactly what it'll be like when done,
what's the harm in trying both red and white to see what I like best. The fittings cost under a buck. Someone suggested possible vacuum leaks. I have the kit and Im fealing brave.
__________________
2000 250 4x4 CC. Hypertech, 4" Banks Exhaust, Shift kit, 315/75 Toyo's, 3.73's. Pulls 22' Toy Hauler, Bed Slide,Snug Top
This is a very very common remod to install 1/4 brass valves in line at or near the heater core . Interupting the flow alltogether. This is also a portion of the FORD Ambulance prep package from the factory for emergency vehicle chassis. We shut the valves off in spring and turn them on in December when it gets cold. Manually underhood. Great thinkin guys
After reading all these post last night it got me thinking, I know that is always scary but I remember the device you guys are all looking for and it is called a Vacuum Solenoid. What it is is a small electric motor that shuts down a vacuum line much like the heater valve shuts down the water line. I was able to locate a couple of them on the internet, one sold for 16.95 and the other one I have not been able to get a price for but I have Summit Racing checking on a price for me. It is sold by Hot Rod Air, part #92-0001, this the address to their catalog online. http://www.hotrodair.com/index.cfm/p...rod/prd172.htm The solenoid would go inline in the vacuum line to the heater control valve when you splice into the red vacuum line and a small switch could be hid just about anywhere that would control power to the solenoid. this would allow you to have arctic a/c, cool vent air and warm bi-level air just by activating a small switch from the driver's seat. My heater control valve will be in on monday and I will be installing it with a vacuum soleniod as I want cool vent air now and warm Bi-level air to darn soon here on the mountain. Hope this helps some you looking for the best of both worlds as I am.
