octane for 534
Old 10-17-2007, 12:54 AM
6t56's Avatar
6t56
6t56 is offline
octane for 534
I read somewhere in these threads that these engines have a low compression ratio because they were built to run on low octane gas( i think he said like 78 octane)because that's what they ran in the 70's.He went on to say this is the reason they run hot because they can't burn all the fuel,meaning that the engine is essentially on choke constantly.
the unburned fuel then goes out the exhaust,This might explain why mine backfires so much.It blew the muffler appart first,now the Y-pipe is coming apart!!If this is all true what can I do about it?Is there a way to lower the octane of the gas you buy?
Old 10-17-2007, 03:37 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
The lower the octane number the easier it is for the fuel to ignite. An incomplete burn could be due to several reasons such as air fuel ratio, timing, combustion chamber design, ect. not the octane rating of the fuel.
Old 10-17-2007, 10:31 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,598 Likes on 1,303 Posts
Even regular was better than 78 in the '70s.
I remember reading the operators manual for my dad's GI GMC trucks. They had some low compression, I almost want to say in the 6's. They spec'd 67 octane. This was from 1952, but man, 67? The 534 is a product of 1950s engineering, but not early '50s.....
534's are obsolete, and you are learning why....
Old 04-01-2008, 12:53 PM
big job's Avatar
big job
big job is offline
I don't know about that , because we had 3 T950.s all 1964s bought new one 534 5x4
and two with Cummings 5x4. I usually drove a diesel and the gas job will blow the doors
of the other two and that inludes Macks Petes etc. You didnt even need the aux trans
they started talking around 3000 rpms tough on gas maybe 3mpg, never broke never
failed, so for $0.30 a gal nobody cared. sam
Old 05-05-2008, 03:23 AM
Brons2's Avatar
Brons2
Brons2 is offline
octane was actually much higher in the 50s/60s thanks to tetraethyl lead...
Old 02-25-2009, 01:58 AM
jonnydesert's Avatar
jonnydesert
jonnydesert is offline
if you're worried up the compression
if you find you have no problems with timing, leaks, fuel pressure, etc. that is causing your rich condition, and you think it may be from the octane (probably not, but I'm no engineer) increase your compression. you can shave the block and heads, run a domed piston, or blow it with a turbo or supercharger, get it up to 11, 12: 1 and you wont have a rich condition, or a lack of power!
dansV10
Computer Chips & Tuners
08-24-2005 02:26 PM
pops_91710
25
03-30-2004 09:02 PM
Geoboy
Modular V10 (6.8l)
20
01-21-2004 09:32 PM
78bigunns
02-10-2003 05:23 AM
Fordman7780
10-29-2002 02:22 AM
Quick Reply: octane for 534
