351m motor trouble
Old 07-17-2006, 11:46 PM
76cougar74100's Avatar
76cougar74100
76cougar74100 is offline
Exclamation 351m motor trouble
distributer rotor will not turn?
could it be the pin?
Old 07-17-2006, 11:55 PM
Socketman's Avatar
Socketman
Socketman is offline
either the pin or the timing chain. yanker up outta there and have a look. it may not look spun as the remains of the pin will still be in the holes in the gear. Be aware that something made it strip, usually somethin has gone through the oil pump. When i used to install engines once in a while a bristle from a wire wheel would make it to the pump. only ever upset fords though. its a weak link.
Old 07-18-2006, 12:25 AM
Bdox's Avatar
Bdox
Bdox is offline
It's not a weak link. It's made that way so the engine won't run if the oil pump doesn't work. The pump just has close clearances, as it should.
Old 07-18-2006, 12:34 AM
Socketman's Avatar
Socketman
how old is this engine ,
Old 07-18-2006, 08:37 PM
76cougar74100
1978 180 000 km
Old 07-19-2006, 09:31 AM
Falcon67's Avatar
Falcon67
Falcon67 is offline
Chain most likely
Old 07-19-2006, 08:06 PM
76cougar74100
i have been told the timing chain may have jumped. it turns over but wont start and it sounds unormal when turning over.
Old 07-19-2006, 11:53 PM
Socketman's Avatar
Socketman
if it seems to turn over too fast , and based on the mileage i would say its timing chain. If when you get it apart it has nylon gears and they are stripped its goin to require pulling the pan for a a good cleaning. I know it doesnt sound like fun but that stuff could potentially get to the oil pump and stop it. gl
Old 07-20-2006, 07:47 PM
76cougar74100
doesnt turn over too fast just rite but i will take a look at the timing chain. and see if the is the problem.
Old 07-20-2006, 09:49 PM
Socketman's Avatar
Socketman
Check the distributor first, if its ok then put a bar and socket ont he front of the crank and look down the hole see if the cam turns and move it back and forth to feel for slack.
Old 07-25-2006, 01:34 PM
76cougar74100
the distributer doesnt turn when cranking over. instead of fixing it should i drop in a 390?
Old 07-25-2006, 04:10 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
A 390 will not "drop in". It will not bolt to the transmission and your accessory brackets etc will not fit.
