What is this extension used for?
Received 3,697 Likes
on
It's actually a custom wrench made for Yugo's; there's a hole in the middle of the front bumper where there is an extension from the balancer bolt, you put a 1" socket on the end and use that wrench to manually turn the engine when it doesn't run. Takes two people to go anywhere, one to lie on the hood and crank and the other to drive....
My best guess is someone broke their only ratchet doing a midnight wrench job and improvised with the extension and a torch, then bent the extension the same way they broke the ratchet.
Maybe I'll contact Advance Auto Parts and see where the Thorsen Co. is and see what they make of it.
If you look at this extension closely, it looks like it's a factory bend, or someone did one hell of a job bending this.
No heat, vise, or hammer marks.
Then again, maybe superman was bored.
For now it's a paper weight.
Okay, been around the mechanic trade for some time now, it a custom extension to be used with any socket, that way you pop on any socket needed and use it like a wrench. No need to carry wrenches, just sockets and that customized bent extension. I seen them done with wrenches sometimes.
buck
buck
