1957 312 Y Block Water Pump
I am changing the water pump on a 312 Y block on which I am using a single exhaust with cross-over pipe. There is not enough clearance to use the water heater hose inlet on the top of the pump. Can I use the side mount located on the drivers side of the pump which is plugged and intended for mounting power steering. I can look through both inlets and they enter into the same chamber inside the pump but I don't know if one is intended for inflow and the other out flow. I don't see how that could be though if they enter into the same chamber. I am trying to preserve the single exhaust if I can to avoid having to buy a new dual exhaust system.
