Radiator Leaking ??
I have had luck re-crimping the seam with a pair of modified pliers to fit the job. If you have a good radiator shop in your area they can do it for you. You'll probably have to remove it tho.
The tanks usually leak because of an installation problem, causing too much stress on the radiator seams. Look at the rubber mounts for deterioration or maybe it's been smacked, bending the radiator supports/mounts.
160k on a radiator seems like the end of it's reliable life. It just costs $$.
