F-150 Ignition Coil woes
Ok , I tried searching the forum , but it came back unavailable.
I have a '02 Supercrew , that has had constant issues with the ignition coils , starting around 50k miles. Of course it was not covered under the extended warranty!
It is not any one coil either, seems rather random. My local dealer says its best to replace them all at once. That it is a known issue as well.
Has anyone tried replacing all at once and if so did that solve the problems???
Seems every other month , I have to replace another damn coil.
And finding the one thats the issue is a beast. It is a intermittent problem , and comes and goes.
Ideas? Feedback? sympathy?
on
1 Post
Hi and welcome to FTE! I moved your thread to the 97-2003 F-150 forum. Someone should be able to help you.
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
-Matt
