F-150 Ignition Coil woes
Old 07-06-2006, 11:09 PM
Prewit_haus's Avatar
Prewit_haus
Prewit_haus is offline
Ok , I tried searching the forum , but it came back unavailable.
I have a '02 Supercrew , that has had constant issues with the ignition coils , starting around 50k miles. Of course it was not covered under the extended warranty!
It is not any one coil either, seems rather random. My local dealer says its best to replace them all at once. That it is a known issue as well.
Has anyone tried replacing all at once and if so did that solve the problems???
Seems every other month , I have to replace another damn coil.
And finding the one thats the issue is a beast. It is a intermittent problem , and comes and goes.
Ideas? Feedback? sympathy?
Old 07-06-2006, 11:57 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
You may wanna post a duplicate thread or have a moderator move this one off to the 1997-2003 F-150 Forum..
But I'm sure the guys here in the '04+ have come across something similar... maybe...
Good Luck...
Old 07-07-2006, 01:17 AM
exiled's Avatar
exiled
exiled is offline
are you replacing new coils yet?
Old 07-07-2006, 05:16 AM
Beast12's Avatar
Beast12
Beast12 is offline
Hi and welcome to FTE! I moved your thread to the 97-2003 F-150 forum. Someone should be able to help you.
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
