Just a couple comments. WOW! Thank you! Looks AWESOME! I have been going over every mustang forum around trying to see who has swapped a 3V 4.6 and what it would take. You have answered almost all of my questions. One I do have, is there anything that can be done about that gas pedal to use a throttle cable, and how hard was it to adapt it the way you did to be drive by wire? I have 2 vehicles getting that motor. A 98 F150 with 160K on the odometer and a 93 mustang. Any advice? I'm using an explorer 4.6 3V as soon as I pick them up. Any idea if the 98 trans will work with it? Thanks man I appreciate the inspiration and the advice. BAD ***!!!!
Hallalujah, praise the Lord. I am so glad there is an alternative to the GM clips and parts. Looks good, but I liked the Mercury wires on it in the first few pictures. That is something not seen in a long time. Great job.
wow. that truck is going to be a head turner. i have a 64 stepside that would look sweet with that setup. what years and models will work for this and how much will the stance of the truck change. wil i still be able to pro street if i decide to or is this swap more intended for cruising.thanks bentts64
