Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-29-2006, 09:01 PM
nhswrld nhswrld is offline
Garage is empty, add now
nhswrld is starting off with a positive reputation.
2.3 common oil leak?
so i have this 2.3 turbo motor i pulled out of an 88 tbird and put in my ranger (im used to big V8's), i just got it crankin over and runnin and it seems to leak oil im guessing somewhere in the timing gear area?...im wondering if it is the front main seal but it is kind of hard to tell...i know the little 2.0 that was in it leaked oil too and it also got shot all over the engine compartment from the belt...
im wondering if there is a typical leak that springs in these little 4 bangers....
  #2 (permalink)
Old 06-30-2006, 12:16 AM
TigerDan's Avatar
TigerDan TigerDan is online now
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
I'd look at the front main seal and the cam seal, but you might also check the turbo oil supply line.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 06-30-2006, 11:10 AM
jamnjm jamnjm is offline
jamnjm is starting off with a positive reputation.
The 2.3 front crank seal in held in a cover. Most don't know this, but you have to center the seal by moving the seal holder before tighten it down.
  #4 (permalink)
Old 07-03-2006, 07:45 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Smile
It is also common for the cam gear bolt to leak. Use lok-tite. Click the image to open in full size. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
Tags
1986, 20, 23, cam, common, crank, engine, ford, leak, leaks, oil, ranger, seal, troubleshooting, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
