What's the torque spec. for exhaust Y pipes to the manifolds. I did 30 ft lb and they leak a little. My Y exhaust pipes don't come with gaskets they have flared ends. It was ok before I removed the exhaust pipes to change the oil pan.
I don't know that there is a specific tq spec...make sure they're seated correctly and tighten them down even more if you want. Or you can leave them and let them work in a little and retighten them about 100 miles later.
Make sure the pipe end is sitting on the manifold cone correctly - you may be uneven and exhaust may be sneaking past one side...don't forget to tighten the bolts evenly as you go on either side (like you would with setting a manifold gasket).
Also check for cracks or damage in the area and to the ball/socket area (the connection points).
