My 1959 F-100 Project
Old 06-23-2006, 06:12 PM
J Hodges's Avatar
J Hodges
J Hodges is offline
I have a 1959 F-100 shortbed pickup truck I also have a 1974 F-100 Shortbed pickup I would like to put the 1959 Body on the 1974 frame and put a 1977 model 302 and a c6 in it I hope it works
Old 06-24-2006, 08:04 AM
59flatbedford's Avatar
59flatbedford
59flatbedford is offline
sounds like its going to be a fun project. on my 59 i but it on a 61 frame with 63 4x4 axels
Old 06-26-2006, 05:00 PM
mcdonaldm's Avatar
mcdonaldm
mcdonaldm is offline
the only big drawback i can see is that the 74 frame will be wider thant the 59 frame. this will make for all new body and bed mounts, plus the wheels will probably stick outside the front and rear fenders unless you use offset wheels to compensate for this.
the trucks up to and including 72 all had the same frame width, so those years trucks would be easier to swap bodies on.
but if you are willing and have the fabrication skills and time, it could be done.
rgds
Mike
Old 06-26-2006, 05:22 PM
51dueller's Avatar
51dueller
51dueller is offline
I put my '51 truck on a '78 F-250 frame. You can check out my tech article here:
http://www.old-fords.com/frameswap/frame1.htm
It might help get you started on your project.
Old 07-28-2006, 12:27 PM
J Hodges's Avatar
J Hodges
J Hodges is offline
Yesterday I finally got the frame cleaned up and painted I have an LTD with a 400 and I am thinking about using it in my 1959 project I just have to pull it out of the weeds to get the motor out I remember it was leaking water so I hope a freeze plug came out and the block isn't busted if the block is busted I will use the 302
Old 07-28-2006, 01:59 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,935 Likes on 1,876 Posts
Sounds like it will be a great project. I had a 1960 F-100 big window in high school. We didn't do a frame swap but we did install all the suspension, engine tranny, and t-case from a 75 F-150 4x4.
It was a cool truck
Good luck
Bobby
Old 07-28-2006, 03:36 PM
59flatbedford
it'll be cool only thing id do is put a manual in istead of a c6. trucks should just have a stick shift and thats all there is to it. but do what ever you want.
Old 07-28-2006, 08:46 PM
J Hodges's Avatar
J Hodges
J Hodges is offline
I was wondering if the old 1959 frame would be worth anything it is complete as far as I know and it has a 223 6 cylinder 3 on the tree I was wondering if it would be worth anything or is it just scrap metal
Old 07-28-2006, 09:04 PM
Randy Jack's Avatar
Randy Jack
Randy Jack is offline
It is definitely worth something to the guy who wants it!!!
Sale price is always dependant on time. If you've got the time...it's got the value.
That guy might read this post. Or, he could come along next year. He'll pay "something" for it.
So...the price you ask is ultimately dependant on how soon you want to sell it.
I might start at $300...and suffer the outrage for a while. But then...I'm greedy that way.
(Excuse me, I always double-space when I think I am being profound...)
Old 07-28-2006, 09:10 PM
sail's Avatar
sail
sail is offline
I had a 59 F-100 myself. Had the 292 V-8. She was one of the best running trucks I have ever had. This was in 1998. Is the chassie so bad that you have to replace it? Or do you just want a more modern one? My 59 (Dorthy) would run with the rest of them and then some.
Old 07-28-2006, 09:17 PM
J Hodges's Avatar
J Hodges
J Hodges is offline
I just want a more modern frame
Old 07-29-2006, 08:14 AM
59flatbedford
they more modern frame will have some advantages but will the counter the time it takes to build mounts. you could put motor and trans mounts in the old frame eaiser than you could swap frames. i changed my frame to that of a 61 but i just wanted 4wd wicth i viewed as worth it.
Old 07-29-2006, 11:24 AM
J Hodges's Avatar
J Hodges
J Hodges is offline
I thought about using the original chassis but I wanted a different motor, transmission , front axle and a different rearend so I figured it would be easier to just use a whole diffent chassis
Old 07-29-2006, 12:24 PM
59flatbedford
are you doing 2wd or 4
Old 07-29-2006, 12:31 PM
J Hodges's Avatar
J Hodges
J Hodges is offline
It is 2wd I would have no use for a 4wd since i have only seen snow about 4 times
Quick Reply: My 1959 F-100 Project
