Rear end ratio on 2007 Expedition
Originally Posted by Monsta
Where does it say that?
4x2's than 4x4's tow more due to the added weight of the transfer case and front driveline of the 4x4. That's the only difference I see.
It shows that Only the Standard 3.31 Rear Axle with Optional HD Tow Package
is the ONLY Expedition capable of towing 9,200lbs
(both 4x2/4x4, Non-EL models)
The Optional 3.73 Rear Axle (on Non-EL models) with HD Tow Package is Only rated for 9,050lbs (150 pounds less)
The Standard 3.73 EL models are rated 9,000lbs for 4x2 & 8,750lbs for 4x4
It appears that to the get max rating from Ford on the Expedition that you can only get it with the standard (Non-EL) 3.31 axle with 4x2 or 4x4
The 3.73 axle on the Non-EL model drops the tow rating down by 150lbs.
This appears odd...
I think it's a misprint. Unless the 3.73 is only available in a 4x4 configuration and the weight of the extra mechanicals is decreasing the rating.
Anyone trying to tow 9000 pounds with a 3.31 axle will be a Pioneer. You remember the pioneers of old? They're the ones with all the arrows in them.
-- Chuck
-- Chuck
Ford Towing Guides tell the story about axle ratio
-- Chuck
-- Chuck
Here is the link for the last few years of Ford Towing Guides: https://www.fleet.ford.com/showroom/...ng/default.asp
chrisc8869
Modular V10 (6.8l)
10-04-2017 06:50 AM
a7xbass94
06-14-2013 09:27 PM
