WVO, Onboard processing
Old 06-21-2006, 03:46 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
Is it possible to make a setup for precessing your used fryer oil on board your truck? Surely a person could set up some kind of system where the raw oil went into an upper tank, and it gravity fed to a lower tank through a filter? Even if it wasn't gravity fed, a person could set up some kind of electric pump.
Does anyone have a setup like this, or is everyone doing the filtering in thier garage?
Reason I'm asking, is a setup like that would work well for someone who was going on a very long road trip.
Anyone, anyone, Bueler?
Old 06-21-2006, 05:00 PM
willbd's Avatar
willbd
willbd is offline
The issue with onboard procesing is time. The longer the WVO sits the more water drops out. Driving would make it harder to remove any water.
The only good thing is you have a good source of heat.
Old 06-22-2006, 03:12 PM
seventyseven250
I'd guess the sloshing while driving wouldn't help any either. How long would it need to sit to separate out a reasonable amount of water? if you had it heating while you drove, and then just let it separate while you parked for the night, would that be long enough?
Old 06-22-2006, 03:22 PM
willbd's Avatar
willbd
willbd is offline
2 of 3 week with some heat cycles.
garmford
6.7L Power Stroke Diesel
46
10-01-2019 01:41 PM
90pioneer
22
09-15-2017 09:35 PM
Thenewboss
08-10-2015 01:07 PM
10thMountainMechanic
Bio-diesel, Propane & Alternative Diesel Engine Fuels
28
09-08-2014 05:27 PM
Rushmore X
06-17-2009 06:58 PM
Quick Reply: WVO, Onboard processing
