View Poll Results: What's your towing MPG?
Voters: 417. You may not vote on this poll
The official -TOWING- mpg Poll
Voted on the 11mpg, actually it's 11.5 from San Diego to Bakersfield or Sacramento. Long stretches of highway doesn't seem to gain much. Up and over the grapevine to Buttonwillow (near Bakersfield) nets 11.5. Buttonwillow to Sacramento, still nets 11.5. Go figure since Buttonwillow to Sac is fairly flat.
I also average 65 mph, up hills, flat, slight incline, the 3v doesn't care!
1. Year - 2005
2. Cab configuration - Crew Cab
3. Current mileage on the odometer - 26k
4. Auto or stick - T/S 5sp Auto
5. 2WD or 4WD - 2WD
6. Rear gears - 4.10
7. Tire size - Stock
8. Cap or no (if a P/U) - Hard bed cover
9. Zero aftermarket accessories.
10. 1750 pound open car hauler with a 3200 pound car plus a bed full of spare parts and tool boxes (at least 1K in the bed).
1. Year - 2005
5. 2WD or 4WD - 2WD
I get under 7 in the mountians, best was almost 9, avg 8.
1. Year -2004
2. Cab configuration - SC/LB
3. Current mileage on the odometer - 39,000
4. Auto or stick - Auto
5. 2WD or 4WD - 4WD
6. Rear gears - 3.73
7. Tire size - stock ??
8. Cap or no (if a P/U) - no Cap
9. Any aftermarket accessory that has had an effect on your mileage if it is far off the forum's average. - no aftermarket performance mods (lost 200 lbs of ugly fat recently, the wife if that counts as a performance mod)
10. Weight, size and configuration of trailer. Fifth wheel, load-leveler, etc, and how much the trailer weighs approximately. - 23.5 ft 5th wheel, 7700 lbs gross
1. Year -2004
5. 2WD or 4WD - 4WD
2 - sc/sb
3 - 54000
4 - auto
5 - 2wd
6 - 3.73
7 - 265 x 75 x 16
8 - no
9 - no
I usually pull a 20' x 6'8" (that's the floor size) gooseneck stock trailer, steel w/covered top and nose (a Circle D, if anyone cares), empty it weighs around 5800#. Most of the time that I'm towing long distances it's to a show, so the load's usually not real big, say 8000# give or take a little. Mileage varies alot with conditions, but with little or no wind and no real long or steep hills, I'll average 10 if I run 60 - 65. I figure about every 5 mph over that costs me 1 mpg.
2 - sc/sb
3 - 54000
4 - auto
5 - 2wd
6 - 3.73
7 - 265 x 75 x 16
8 - no
9 - no
1. Year = 2004
2. Cab configuration = crew cab, long bed
3. Current mileage on the odometer = 16,400
4. Auto or stick = auto
5. 2WD or 4WD = 4wd
6. Rear gears = 4.30
7. Tire size = stock, 265/75R16E
8. Cap or no (if a P/U) = no
9. Any aftermarket accessory that has had an effect on your mileage if it is far off the forum's average. = Bank powerPack
10. Weight, size and configuration of trailer. Fifth wheel, load-leveler, etc, and how much the trailer weighs approximately. = 27" Travel Trailer with slideout. Only 7500 lbs but it is higher than my last trailer and pushes more air.I had been getting 7 to 7.5 pretty consistently until this year. In the off season, I had the 3.73s changed to 4.30 and added a Banks PowerPack with TransCommand and Ottomind and now have been getting 8.5 to 9. It may not seem like much but, I can go another 35 to 70 miles between fuel stops now or stop at the same places and get less gas!
5. 2WD or 4WD = 4wd
close to 7 with ac and close to 8 without ac
average of around town and highway
1. 2005
2. crewCab
3. 22,000
4. Auto
5. 4WD
6. 4.10
7. 275\70-18
8. no cap
9. 200 gal. spray tank in bed-average between 1-2k in bed weight
10. cargopro inline enclosed trailer\dual axle-gross weight 6-7K-have a 200gal. tank in trailer, weight depends on how full it is
1. 2005
2. crewCab
3. 22,000
4. Auto
5. 4WD
6. 4.10
7. 275\70-18
8. no cap
2. CrewCab srw
3. 10,000 miles
4. Auto 5R110w TorqShift
5. 4WD
6. 4.10 LS
7. 265/70-17
8. Tonneau cover
9. None
10. 27' travel trailer which weighs 7500 loaded, combined weight usually scales in about 15,500 to 16,000.
Towing at 60 average is 8.5mpg, low is 7.5mpg, and all time high is 11 with a good tail wind. Voted 8. Getting a new fiver which I am picking up next week and will be going on a 10 day shake down trip. Will post change in mileage with new unit.
Doug
2. CrewCab srw
3. 10,000 miles
5. 4WD
6. 4.10 LS
7. 265/70-17
8. Tonneau cover
9. None
Doug
I average about 6 - 7 when pulling in hills mostly. On flat I might get 7.5.
When I pull my smaller trailer (9,000 lbs) I get about 8.5 - 9.
1. 2003
2. Crew Cab
3. 51,000 Miles
4. 4R100 Auto
5. 2WD
6. 4.30:1
7. 265/75R16
8. Open Bed
9. Banks Power Pack
10. 36 foot 5er toy hauler. 3 axle, approx. 21,500 lbs gross combined truck and trailer.
1. 2003
2. Crew Cab
3. 51,000 Miles
4. 4R100 Auto
5. 2WD
6. 4.30:1
7. 265/75R16
8. Open Bed
9. Banks Power Pack
In keeping with Monsta's MPG polls, I decided to make a towing MPG poll.
This should be for towing mileage results after a few hundred miles.
In your post put the following, please.
1. Year 2000
2. Cab configuration Crew
3. Current mileage on the odometer 68,000
4. Auto or stick Auto
5. 2WD or 4WD 2WD
6. Rear gears 3.73LS
7. Tire size 285/75-16
8. Cap or no (if a P/U) Open bed w/ tailgate
9. Any aftermarket accessory that has had an effect on your mileage if it is far off the forum's average. None
10. Weight, size and configuration of trailer. Fifth wheel, load-leveler, etc, and how much the trailer weighs approximately. 6' x 12" enclosed cargo trailer w/ 2 axles. Approx 4,500#. 10mpg towing @60-65 mph
PLEASE KEEP IT V10 MPG RELATED
1. Year 2000
5. 2WD or 4WD 2WD
2. Crew
3. 24,500
4. Auto
5. 4x4
6. 4.10LS
7. O/E 275x70R18
8. No cap but 2 full size atvs on top of bed
9. Dynomax Super Turbo muffler, no gains noticed
10. Jayco 28FKS, 29' approx 7500 pounds loaded, Reese hitch and 1200 pound bars Total weight around 16,000 pounds or more.
6-7 mpg towing with mountain hills 6% grades
9 mpg towing flats @ 65 mph.
2. Crew
3. 24,500
4. Auto
5. 4x4
6. 4.10LS
7. O/E 275x70R18
2-f350 super cab short box
3-4.10
4-10500 miles
5-auto
6-BONE stock
7-275-18 stock conticraps
8-toneau cover
towing 79 bronco on 18' us cargo,around 8000lbs.100 mile trips each way(silver lake)get between 8.5 - 9mpg.always 5-10 mph over speed limitjust got over 14 for the first time empty.all hand calculated.bronco gets 5 mpg,better when towed.
3-4.10
4-10500 miles
5-auto
6-BONE stock
8-toneau cover
#28
I got these figures while towing my 32 ft. Alumilite travel trailer in and around Colorado. My truck does seem to get better mileage at higher altitudes 6 to 10 thousand feet. When I checked it at lower altitudes (sea level to 3000) the mileage was in the nine mile per gallon range.
1. 1999
2. F-250 crew cab long bed
3. 89,000 miles on odometer
4. manual, four speed with 5th over
5. two wheel drive.
6. 373:1 LS rear end
7. 265/75R16
8. no cover, open bed with stock tail gate
9. Factory original, no mods.
10. Don't know the weight of my trailer. I have two trailers, the one mentioned above and a 26 ft. enclosed car trailer that I haul my 56 F-100 around in. The car trailer not only has my 56 in it but also a full work bench in the front with steel over head cabinets, a vice, air compressor, and a tool chest siting on a rollaway cabinet plus a couple of hundred pounds of spare parts.
Michelle
1. 1999
5. two wheel drive.
7. 265/75R16
Michelle
#29
A foot note to the above. I believe the manual transmissions seem to do better on gas than the automatics due to the lack of parasitic slippage. Also I might add that I traded a 91 F-250 with a 351 W and a five speed manual and 3:55 rears and pulling the same Alumilite travel trailer it got about the same mileage as the V-10. So I guess there are indeed technological advances in the gas mileage war.
Michelle
Michelle
#30
adwjoe
Like I mentioned in another discussion I make 10MPG towing our trailer. I rarely hit 65 on the freeway due to the height of the trailer and the bad feeling around tractor trailer rigs.
Year= 2003
Super duty, Super Cab, XLT, Sport Edition
Miles=27K
Auto Trans
2 WD
18" Michelins
Tonneau Cover
Add ons= K&N intake system, Helix Tower Power, Flowmaster Exhuast
Trailer= 25' Sprinter Travel Trailer, Approx 6800#
Year= 2003
Miles=27K
Auto Trans
2 WD
18" Michelins
Tonneau Cover
