filters and wvo
Old 06-16-2006, 10:36 PM
14psd's Avatar
14psd
14psd is offline
filters and wvo
Ok I want to run wvo and not have to change fuel filters every other week. For those of you doin' this (and I'm sure this has been asked before) what is your process. Get wvo, let sit for week or so, filter oil, fill tank, heat oil, here's where I get lost. I don't want the brown grit looking stuff in the bottom of the fuel bowl so what do ya'll do. I have the bag filters to filter down to 1 micron and also a filter to get the water out. Please help.
Old 06-17-2006, 06:42 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
Well it sounds like you're doing the right things. I filter through a bag filter into a drum which I have a heating element in. I heat the oil for about an hour twice a day for three days. The heater is on a timer. Then I pump this oil through two Goldenrod filter on it's way to the storage drum.
If you are plugging filters in a few weeks and say less then 4-5K miles you may just have real fatty oil.
What type of on board fuel filter are you using? Is it heated?
A cold filter will plug much faster then a warmed filter. Warmed oil hitting a cold filter will also cool the oil and cause blockage as the fats plug up the filter.
Lastly check you oil is it hydrogenated
Old 07-02-2006, 12:22 AM
14psd's Avatar
14psd
14psd is offline
I figured out my problem was the HIGH pressure lines from the FPR. They were leaking!!!!!!!! bad. Fixed the prob and now have over 2000 miles on this fuel filter. I also have an extra filter right after the fuel exits the tank which filters the oil again down to 2 microns. I also filter my oil with a bag filter from McMaster-Carr. It filters down to 1 micron. Both seem to be doing the trick now.
mozzles
01-19-2013 08:25 AM
zhilton
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-30-2009 07:32 PM
IceboxFX
31
06-29-2008 05:33 PM
6.0superduty
03-19-2008 11:44 AM
edub32
Alternative Fuels, Hybrids & Mileage
17
07-05-2005 07:56 AM
Quick Reply: filters and wvo
