12" Sub in CC F250 Question
For those of you who have a Super Duty Crew Cab..... were any of you able to fit one or two 12" subs behind the rear seat??I know it can be done, b/c I've seen it oh CarDomain numerous times, but When I went thru the trouble of pullin my rear seat, the truck box that I bought for a 12" sub was WAY to shallow for the Sub (its an Eclipse sub), and I don't know of a deeper 12" truck box..... so how did y'all do it?? Does everybody just run a lower end 12" that has a smaller magnet and depth on it?? I hate havin my sub just sittin in my backseat floorboard takin up room (in a hatchback box)
Thanks for any info and/or pics
--Ryan
--Ryan
I have a F250 crew cab .. and have 4 10's behind the back seat .. yup 4 ! .. the box was custom made by the installed .. i have 10" crossfire subwoofers and it will rattle the truck. All the items behind the back seat and they made it to totally fill the area, to have enough air for the subs .. I think it was about $200.00 for the box since they did my whole system
Here is a photo of 2 12" alumapro subs behind the rear seat, rear seat in factory position, power sliding window works. I previously had 1 10" Treo sub, but it did not have close the bass as 2 12"
https://www.ford-trucks.com/user_gal...112631&width=0
I had a 01 cc 250, I bought a pro comp 12 box and mtx 5500 series 12 sub. The box fit perfect but the sub was a little to long in depth. I took a scrap piece of plywood siliconed and screwed it to the box before installing the sub worked perfect. The only problem was when i traded my truck the box wouldnt fit in my 06 because of the power back glass. Once again got the saw out and started cutting, me and my friend notched the box and resealed it to fit around the window unit and it fits perfect.
