Instrument swap
Old 06-06-2006, 07:00 PM
preppypyro's Avatar
preppypyro
preppypyro is offline
Instrument swap
I have been trying to check and see if previous threads if you can do this but cant really find a solid answer. I have another instrument cluster from a 97 with a mechanical odometer with a tad more kilometers on it and would like to swap it into my truck. Would there be any problems with the computer if the odometer read a little bit more? Do you know can guy bring it into ford and get them to change the odomter to read what my old one does? Thanks!
Old 06-06-2006, 11:19 PM
Smaug's Avatar
Smaug
Smaug is offline
Ford will not adjust it but the 'puter will not have any trouble w/ the new one.
Old 06-07-2006, 09:06 AM
preppypyro's Avatar
preppypyro
Sweet thanks for the reply man. It does kind of suck that it reads abit higher, but least everything will work properly now!
Old 06-07-2006, 01:50 PM
Smaug's Avatar
Smaug
Smaug is offline
Just take pics of both of them together to document the fact that the new one has higher mileage.
Old 06-07-2006, 08:14 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
i have heard on the newer trucks, if you change the instrument cluster, the computer will recognize the "tampering" and will not let the ignition key work. you may have to have FORD reprogram the key after changing the cluster. dont know if this is true on the 97-98 versions or not. i believe it is for the newer electronic- digital odometers.
Old 07-09-2006, 02:25 PM
Bob Brown sr's Avatar
Bob Brown sr
Bob Brown sr is offline
Are we saying that we can change the cluster and computer will not know the difference? What if the digital display (actual mileage vs replacement mileage) is different, will the old mileage come up or the mileage on the replacement cluster, mine has a cloudy look to it?
Old 07-09-2006, 02:34 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
The cluster stores the mileage.
