70 - 76 Suspension swap?
Matt, that is an easy one. It bolts right on where the old stuff came off. It might be easiest to use the 76 gear complete, unbolt the I beams on their inside mount, and undo the nuts at the rear of the radius arms. Keep in mind you will want a correct proportioning valve and master cylinder to go with those new disks. DF
Thanks for the info, I already have a master cylinder off the 76, I will be using it for a core, My truck was equipped from the factory w/ power brakes can I use my booster with the 76 master cyl. I plan to get the proportioning valve in the next couple of weeks.( off a 77)
corkel
01-08-2015 03:35 PM
pipman76
05-04-2008 08:29 PM
highrider76
02-16-2006 08:08 PM
