Swaybar droplink questions
Old 05-29-2006, 08:54 PM
rebelchevy02's Avatar
rebelchevy02
rebelchevy02 is offline
I did some searching and came up with 4.5816 as the p/n for the swaybar/ droplink bushings, then in another thread i saw that someone stated the droplink bushings that come are 1/2" or so too big, so anyone know the correct p/n for them? Ive replaced the droplinks before, and they are kinda salty from the dealer, and dont last, so im looking to go poly. Any help? or should i just wait around till daylight and call energy suspension up?
Old 05-29-2006, 09:18 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
energysuspension does not sell their products to retail customers. you have to go locally or off of the internet from a dealer to buy them. the part number for the poly bushings (in red) for the swaybar to axle joint is 4.5186, yes. but the actual bushings on the drop links (one at each end) may actually be the problem. i thought my problem with the clunk was at the axle, but actually one of my end link bushings was shot to hell. havent drove on them yet, but i think it fixed the problem.
Old 05-29-2006, 09:31 PM
cangim's Avatar
cangim
cangim is offline
you can also check out Napa for endlink relacement bushings, they are a blue poly, that is what I used on mine and no longer have any clunks.
Old 05-29-2006, 09:33 PM
rebelchevy02
So i can get the droplink bushings in poly from NAPA? that would be cool since i get garage pricing, and i was looking for them from poly, i just thought that the above listed p/n was for them and the axle mounted bushings
Old 05-29-2006, 09:40 PM
cangim's Avatar
cangim
cangim is offline
yes, not sure what type of poly but if you key word search stabilizer on Napa's site with your truck selected it should pull up front and rear replacement parts.
Old 05-29-2006, 09:50 PM
rebelchevy02
only thing i came up with on their site is the bushings at the axle, so maybe ill just give them a call
Old 05-29-2006, 10:04 PM
sgrol's Avatar
sgrol
sgrol is offline
Check my gallery. I did the bushing replacement a month or two ago.
Old 05-29-2006, 10:25 PM
rebelchevy02
Ok, well i guess ill give the 4.5186G a try, assuming it fits right, ill have to do about 7 sets of them as our company has 7 SDs, thanks for the info
Old 05-30-2006, 09:26 AM
cangim's Avatar
cangim
cangim is offline
Not trying to push in either direction, but here are the part numbers for bushing kits from napa. Rear is NCP2651544; Front is NCP2651543. These are the actual bushings that go inside the drop links, sounds like the bushings for the axle you have already found.
Mr. Ed
12-22-2016 08:51 PM
flipklos
04-14-2010 02:22 PM
DAVE67FD
1999 to 2016 Super Duty
05-08-2009 06:46 PM
cujo8
08-18-2006 06:59 PM
smassie88
04-20-2004 09:09 PM
Quick Reply: Swaybar droplink questions
