Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
New! Use your Facebook to securely log into this site, click logo to login
1967 - 1972 F-100 & Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-22-2002, 04:16 PM
mtcwby01 mtcwby01 is offline
mtcwby01 is starting off with a positive reputation.
weird carb spacer
Hi I have a 1969 F-250 4x4 with a 360. I have a question for someone. It has a 2 barrel intake on it now with a 2100 autolite carb. Under the carb is a spacer in which there is hose connections that are T'd in with the heater hoses. When the heater water valve is opened, water flows not only to the heater, but also through the spacer underneith the carb. I always thought carb spacers were to help keep the carb cool and to also help fuel atonimation.-"spelling is wrong" The only thing i can see that the spacer with the water flowing through it would help is when its cold and conditions are right for carb icing. Am i right? Any input is appreciated.
Thanks Ben from Montana
  #2 (permalink)
Old 02-22-2002, 06:18 PM
jowilker's Avatar
jowilker jowilker is online now
1966 Ford F-100
jowilker has a great reputation on FTE.jowilker has a great reputation on FTE.jowilker has a great reputation on FTE.jowilker has a great reputation on FTE.jowilker has a great reputation on FTE.
weird carb spacer
Ben, It was one of Fords better ideas for warming the carb.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
Following FTE on Facebook http://www.facebook.com/pages/Ford-T...5588400?ref=ts
  #3 (permalink)
Old 02-22-2002, 06:29 PM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
weird carb spacer
I think the word you're looking for is 'atomization' I can't imagine any other reason for that design than what you mentioned. They seem to be pretty rare, I've only come across a couple here in Alberta.(Great White North):-X12
  #4 (permalink)
Old 02-22-2002, 07:06 PM
Hawkeye58 Hawkeye58 is offline
Hawkeye58 is starting off with a positive reputation.
weird carb spacer
I had that same spacer on my '68 390. I changed to a 4 barrel so it's gone now though. My thought on it is this: Ford stopped putting it on their engines not long after that year, so, they must have found they didn't need it. Otherwise they would still be using it. Make sense?
If you are going to stay with the two barrel, then just re route the water lines and don't hook them to the spacer. I don't think hot water is a "Better Idea" for the carb. I love my Ford, but I think they goofed on that part.
Hawkeye
  #5 (permalink)
Old 02-22-2002, 09:40 PM
weird carb spacer
Hi Thanks for the info. If U guys are wondering, i'm soon gonna put on a Edelbroch RPM and 600 CFM carb. A 390 crank rods and pistons and bigger cam are on the way also. I have a question for U guys. I was wondering if U can put a 428 crank in a 390 or 360 block. I know the heads are the same, but i was wondering if the main bearing journals would be in the right locations. If anyone has done this swap before or knows any info about it, I'd appreciate it.
Thanks again,
Ben from Montana
  #6 (permalink)
Old 02-22-2002, 11:12 PM
karlsd karlsd is offline
karlsd is starting off with a positive reputation.
weird carb spacer
Yes, you can. Ford did it first. In 1966 and 67, Mercury had a 410 cid engine available. It was nothing more than a 428 crankshaft in a 390 block. I'm doing it right now to my 1969 360 block. The only thing to keep in mind is that you also need to get a new flexplate, because the 410/428 is externally balanced, whereas the 360/390 is internally balanced.
  #7 (permalink)
Old 02-22-2002, 11:59 PM
Art Art is offline
1967 Dodge Coronet
My Garage
Art is starting off with a positive reputation.
weird carb spacer
Just so you guys know, Ford did indeed continue heating carbs after they removed the coolant hoses from the carb spacer. Take a closer look and you'll see later on they used the exhaust crossover passage of the intake to heat the carb spacer. Problem is that if you don't use the right gasket, you end up with an exhaust leak at the carb spacer!?!
I run my '69 F100 all year round with the carb air "heated". I closed off the fresh air intake of the air cleaner so 100% of the air is pulled off of the pass side exhaust manifold through the flex-hose. It creates better fuel atomization which allows leaner fuel mixtures as well as better combustion. That truck gets 16-18MPG with a stock 302 - even with my heavy right foot. I have gotten 20MPG on trips, and am sure it could be better but that's no fun. If I am towing something heavy in summer or the weather is extremely hot (rare in Wisconsin), I simply remove the flex-hose going to the exhaust manifold and then it gets "fresh air".
My drag car is a whole different story. I blocked the heat crossover in the intake with a special intake manifold gasket made by FelPro. With the "cold" intake manifold and a 1050 Holley Dominator, its really crabby at anything below 60degF - even though its adjusted somewhat rich for max power.
I'd say it depends on what you want out of your truck - maximum power, a compromise between power and driveability, or just driveability. It also depends on your climate.
Art
__________________
Wanted: parts for a 1930 Dodge (DD model) coupe or sedan
Here's one of my trucks, the rest are in my gallery...
  #8 (permalink)
Old 02-25-2002, 01:31 AM
jdbanks's Avatar
jdbanks jdbanks is offline
jdbanks is gaining momentum as a positive member of FTE.
weird carb spacer
I looked today cause I remembered I had that spacer with the water heating on my 68, and I also have it on my 67 which has the motor from a 72. So they must have still been doing it in 72 then.
So is it a good or a bad things? Should I go to the effort to pull the water from it or just leave it be? Curious.
-j.banks-
__________________
J. BANKS
TEXAS Chapter Leader
http://www.ford-trucks.com/user_gall...toid=8477&.jpg
Everything's bigger in Texas. Come join the TEXAS chapter.
  #9 (permalink)
Old 02-25-2002, 02:14 AM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
weird carb spacer
My 69 F250 with 390 had the spacer until I went to the Ed Intake and carb. Now I have a few less hoses :-)
Greg
__________________
Gtex
RIP 68 F100
67/69 Hybrid F250 CS 446 CI FE C6, Boat Towing Drag Strip Truck
My Project
  #10 (permalink)
Old 03-01-2002, 09:17 AM
Erik R Erik R is offline
Erik R is starting off with a positive reputation.
weird carb spacer
My '71 F-250 w/360 2 barrel has the same spacer you describe. My '69 with a 390 had it too. Might be nice in colder climates, but here in Calif. it just too hot for this. The carb just boils over into the intake when the truck is at operating temperature and makes the truck hard to start. I disconnected the water lines to it and am thinking of finding a phenolic spacer to put in it's place. Anyone know of a good source for this?
__________________
Erik R.
  #11 (permalink)
Old 03-01-2002, 05:15 PM
weird carb spacer
Summit Racing, or Jegs has the Phenolic spacers.
I found spacers at Autozone and Pep Boys as well.
Then of course any speed shop in your area will have them too.
Hawkeye
  #12 (permalink)
Old 03-01-2002, 05:17 PM
jowilker's Avatar
1966 Ford F-100
weird carb spacer
__________________
  #13 (permalink)
Old 07-25-2009, 07:11 PM
1972-34ton 1972-34ton is offline
1972-34ton is starting off with a positive reputation.
Hot water carb spacer picture
Stock.
__________________
I said, "the nut went down the intake manifold!"
That's when the pain started...
  #14 (permalink)
Old 07-26-2009, 05:29 AM
jowilker's Avatar
1966 Ford F-100
Wondering why you would add a photo to a 7 year old post?
John
__________________
  #15 (permalink)
Old 07-26-2009, 06:48 PM
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Because ThrityFourTon knows Alvin is easily entertained and would find it cool. :)
That's why. ;)
Alvin in AZ
Tags
1969, 200, 360, 390, barrel, boat, carb, carburetor, cid, f100, fe, find, ford, help, phenolic, spacer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
