1972 F-250
Old 03-16-2002, 10:27 PM
66 Ranger's Avatar
66 Ranger
66 Ranger is offline
1972 F-250
Old 03-18-2002, 10:33 PM
paul_pate's Avatar
paul_pate
paul_pate is offline
Post 1972 F-250
I am looking at buying a '72 F-250 "parts truck" to upgrade my '66 F-100. I am wanting to take the entire drivetrain, suspension, and air-conditioning from the '72 and put it on my '66. The '72 has power-steering w/ fluid cooler (interesting), factory air conditioning, power disc brakes w/ 2-piston calipers (interesting), 8-lug wheels, and a Dana rear-end. My first question is: Is this brake system feasible to put on my '66? The disc conversion tech article does not mention this particular system.
My second question is: Should I use the Dana axle instead of the 9" open rear already under my '66.
Old 03-19-2002, 01:32 AM
masterbeavis's Avatar
masterbeavis
masterbeavis is offline
1972 F-250
I think every thing should bolt up with little to no modifications except the factory air. That I dont know about. The swaping of the front brakes is easy. Take off the whole I beam from both sides and swap it in. If you do this, you might as well do the rear end too, why would you want 8 lug in the front and 5 lug in the rear?
Tony
'74 F250. 460, "beater"
'73 F250, "midnight auto" now a trailer
'77 F250, 460 transplantee, "Flamer"
Old 03-19-2002, 04:58 AM
jowilker's Avatar
jowilker
jowilker is offline
1972 F-250
Paul, gotta thought, why don't you just move the sheet metal to the 72 chassis? The chassis vin is the only problem that I can see, if you don't mind the stiffer suspention of the 3/4 ton truck.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old 03-19-2002, 11:44 AM
Sunny_in_hollister's Avatar
Sunny_in_hollister
Sunny_in_hollister is offline
1972 F-250
I've got a 1969 with factory air, but don't know if there were changes to the 1972. Everything inside the engine compartment should bolt up. But I don't if the factory AC unit will bolt to the inside of your truck. It is a big, under dash type affair. I don't have my manualls with me, or I would be able to scan some pictures for you.
Reggie
