Here I go
Old 05-20-2006, 10:48 PM
willbd's Avatar
willbd
willbd is offline
Talking Here I go
Just completed the upgrade to WVO.
Going for the first test ride.
Bryan
Old 05-21-2006, 08:32 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
good luck. Tells us more about the truck and the conversion
Old 05-21-2006, 09:26 PM
willbd's Avatar
willbd
willbd is offline
Talking
The truck is a 95 350 with 145K.
I purchased a Greasel kit and installed it last Saturday.
I added an electric tank switching valve on the return line so when the engine is running WVO flows back to the tank instead of looping the return back to the fuel pump. If the fuel filter on my WVO plugged them I would pull fuel thru the return line to the pump bypassing the heated WVO filter.
The plan is to run a mix of diesel and WVO in my heated front tank and bio-diesel in the rear.
Bryan Will
Old 05-22-2006, 08:25 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Not a good idea. Diesel and VO will not stay mixed. They will seperate into layers and you will be running straight diesel or straight VO so why bother.
Additionally if you should happen to shut down on straight VO your gonna have a problem getting it started again.
Old 05-22-2006, 08:26 AM
Dave Barbieri's Avatar
Dave Barbieri
Dave Barbieri is offline
Bryan Will
Bryan -
There's been a LOT of discussion on the compatibility of vegetable oil and diesel fuel. Go back and check these threads:
https://www.ford-trucks.com/forums/s...=488066&page=3
https://www.ford-trucks.com/forums/s...d.php?t=490845(Post #13 is my response on a simple test to see this for yourself.)
Bottom line - don't mix the two! Heat/motion don't help, and in the end, it's your injection system (and your wallet) that suffer.
Old 05-22-2006, 09:13 AM
willbd's Avatar
willbd
willbd is offline
Question
I am running a 2 tank system.
Front tank is heated with 90% WVO and 10% diesel.
I start on the diesel form the rear tank. When the fuel in the WVO & diesel tank is warmed up I switch to the front tank. The system has both heated filters and fuel line.
I under stand that WVO and diesel will separate out when the fuel in the tank is just sitting.
When you heat the fuel it should cause a thermal currant to help it mix the WVO and diesel. I drive about 20 miles before switching to WVO & diesel mix.
Do you see a problem with this system?
Bryan Will
Old 05-22-2006, 09:21 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Bryan Will
Bryan, If you have a heated WVO tank there is no need to mix dino-diesel with your WVO. Just use WVO in that tank, adding D-2 is just a waste of $$$$$$$$$$.
FABMANDELUX.
Old 05-22-2006, 09:28 AM
willbd's Avatar
willbd
willbd is offline
Smile
So what everyone is saying is just heat the hell out of the WVO and be happy running for free.
Bryan Will
Old 05-22-2006, 09:30 AM
fabmandelux
Bryan Will
Yep
FABMANDELUX.
Old 05-22-2006, 09:47 AM
Phydeaux88's Avatar
Phydeaux88
yup, mixing in the #2 accomplishes nothing and costs money.
Corner Gas
15
04-23-2013 08:21 PM
Greywolf
Testing.....
25
03-19-2008 08:37 PM
mustange70
Canadian National Chapter
13
05-19-2006 01:21 PM
ford390gashog
Oil & Lubrication
02-13-2005 08:47 AM
Quick Reply: Here I go
