6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 service costs
Old 05-16-2006, 11:50 PM
bear1's Avatar
bear1
bear1 is offline
6.4 service costs
I am a ford tech and just got some training info on the 6.4 .The repair costs for these new trucks after thay are off warranty is going to be crazy one of the first classes we will learn to remove the cab off the frame because almost all sevice will require the cab to be taken off .It will also have a totaly new pcm setup to make it allmost impossable to chip
Old 05-17-2006, 12:05 AM
bear1's Avatar
bear1
bear1 is offline
This new motor is going to be a lot more advanced than the sick o . No more high psi oil system , it will have fuel coolers seperate pcms for trans and motor .Its a all new deal nothing is the same as the 6.0
Old 05-17-2006, 05:31 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
…..See you on the boards.
Old 05-17-2006, 08:46 AM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
More, more, more... What else did they teach?
Old 05-17-2006, 09:13 AM
kw5413's Avatar
kw5413
kw5413 is offline
WOW...Welcome to the 6.4 Forum at FTE bear1
Great info. It will be interesting to see if there will be any warranty extensions with this new strategy.
At first blush, I would have to say that the seemingly increased up front cost and post warranty cost may keep many casual diesel buyers out of the market.
But then again, maybe the introduction of the 6.4 will enhance the resale value of my very good 6.0...
Thanks again for the info.
Old 05-17-2006, 09:38 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Glad I bought my 6.0
Old 05-17-2006, 12:01 PM
mizzitch's Avatar
mizzitch
mizzitch is offline
bear 1
Any word on the engine being linked to the navigation/radio display? Supposedly the display will show engine info and check engine codes.
Any word on a 6 spd automatic?
Old 05-17-2006, 05:58 PM
bear1's Avatar
bear1
bear1 is offline
havent heard to much else yet I do know thay will hit the lots in jan 07 as 08s the reason for the delays was for the crash testing of the new front end and easyer to remove cab thats why the front end was redone thay had tryed a flip
nose but it didnt do well in crash testing . Also all the coolers are going to be atached to eachother so thay can be installed and removed as a unit and it will have a electronicly controled high psi fuel sys no more high psi oil sys fireing the injecters
Old 05-17-2006, 06:55 PM
MIKE1646's Avatar
MIKE1646
MIKE1646 is offline
I leased my current truck, do on Jan 08 then 6.4
Old 05-17-2006, 08:48 PM
elemint's Avatar
elemint
elemint is offline
Great. ANOTHER Ford screw up. Hey lets design a vehicle without thinking about how it will need to be fixed....
Old 05-18-2006, 01:50 PM
fordmantpw's Avatar
fordmantpw
fordmantpw is offline
But they did. Did you not read all his posts? He said they made the cab easier to remove, hence additional crash testing. Get your head out of your backside and quit being so freaking negative!
Old 05-20-2006, 07:19 PM
RichS2659's Avatar
RichS2659
RichS2659 is offline
He is right as how much will it cost to remove the cab after the warranty is up compared with flipping up the hood. It will be very expensive to have something done when Ford isn't paying for it. The motor will run for thousands of miles but the all the small but very important parts like water pumps, alternators, PS, etc will get expensive just to get to them to remove them. This sounds like the old 75 Chevy Monza with a 305 that you had to jack the engine up on one side to get the plugs out.
Old 05-20-2006, 10:37 PM
bf250's Avatar
bf250
bf250 is offline
cab easy to remove? when has a cab ever been easy to remove? certainly not easier than just popping the hood.
Old 05-21-2006, 09:37 AM
MIKE1646's Avatar
MIKE1646
MIKE1646 is offline
It might be like a tractor..
Old 05-21-2006, 11:12 AM
captain p4's Avatar
captain p4
captain p4 is offline
Obviously its not going to be as easy as just popping the hood, but what he's saying is that Ford designed it so that the cab is easiER to remove than in previous years. Sucks that they couldn't get a flip hood to do good on crash testing, that would have made things really easy.
Quick Reply: 6.4 service costs
