OK, I was curious what the best carnage you got form wheelin, hope you got pics, I don't but mine was new front end, front clip both MM hubs and two new Bigfoot MT's. airborn into pond nose first...
The only problem I ever had was the bead coming off the rim in the worst part of the mud and BARELY made it out(just enough dry ground to jack up the axle and swap tires).
blown beads, heck just use some mud to seal up hte bead long enough to get some aire in there pump em up and go. I usually knock a tire off the bead atleast once a race it seems.
before i went to 1410 rear driveline i think it was 8 1330 joints and a couple shafts. broke lift blocks(back in myhighschool days dumping the clutch on pavement), recently cracked my frame, rear 60 shaft, 3 front 1330 joints and 2 pinion yokes, 1 t-18, 1 np435 tranny, sector shaft, tie rod bla bla bla
people that take their trucks off road and break parts then blow money on new parts just to break them are idiots. off roading is bad for the environment and pollutes our water and kills brown bears anyway
off roading is dumb
off roading is dumb
KO went all green peace on us.. he even went far enough to take the swampers off his truck https://www.ford-trucks.com/user_gal...id=114962&.jpg. whats next, ivan selling his truck and buying a hybrid or pro running 235/70/R16.5s?
