63 ford ranchero
The 260 V8 was a factory option in 1963. The 5.0 is a derivation of the 260. Using 1963-1965 Falcon frame mounts and insulators will let you bolt the 5.0 into the 63 Ranchero. Trans mounts aren't quite as clear. The trans you use will dictate which mount you go with. The Falcons had a cantilevered spring mount, unlike other Fords. As the previous post indicated, Dearborn Classics, as well as other Falcon vencors, should have the pieces to complete the install.
Good luck
Roger Carter
Good luck
Roger Carter
johnnychrome777
1961 - 1963 F100 Unibody
09-06-2012 11:47 AM
63 diehard
12-04-2001 11:31 PM
