Can someone desktop dyno this 351 combo for me?
I am building a 1991 speed density 351w .030 overbore standard hypertetic dish pistons and this speed pro cam.
Camshafts
Engine . . . . . . . . . . . . . . . . . . S. mall Block
Lifter Type . . . . . . . . . . . . . . . H. YD
Cam Lift Int. . . . . . . . . . . . . . .. 260
Cam Lift Exh. . . . . . . . . . . . . .. 278
Valve Lift Int. . . . . . . . . . . . . . ..4 16
Valve Lift Exh. . . . . . . . . . . . . ..4 44
Duration @ .050 Lift . . . . . . . 197/209
Duration @ .006 Lift . . . . . . . 280/293
Lobe C/L . . . . . . . . . . . . . . . . 114
Overlap . . . . . . . . . . . . . . . . . 60
Cam Series . . . . . . . . . . . . . . Pro-2000
Can someone run it on the desktop dyno and give me an estimate?
Thanks, Matt
Camshafts
Mfg. . . . . . . . . . . . . . . . . . . . . F. ord
Thanks, Matt
Well realisticly, you need more info about the cam. It sounds like some sort of stock cam, I need the intake and exhuast opening and closing events, like the IVO, IVE and EVO, EVC.
Im gonna give an estimate of 212hp at 3500 rpm to 4000......I wouldnt run that cam honestly....I could pick 100 cams that would be better.
Dezertracer
10-07-2012 11:34 PM
Dezertracer
03-08-2010 09:55 PM
65fordguy
05-07-2008 01:34 PM
STGFordCrazy04
08-09-2006 06:40 PM
stripe
05-15-2006 05:01 PM
