Where is the water temp sending unit on the I6?
on
It's on the back of the engine, you have to reach up between the firewall to reach it. Can be a PITA.
From where your oil sender is, you should see a lone wire reaching out toward the back.
You should see it going around to the back of the engine with all it's heat protective plastic on it.
Follow that wire and you should be able to feel it. I doubt that you can see it, unless you stand on your head.
It's on the rear passenger side, basically opposite the oil sender unit but a bit higher up. On a van it's staring you in the face as soon as the doghouse comes off, but in a truck it's in never-never land. There's a recent thread about adding a secondary temp sender with several good suggestions... look it up. I'd leave the stock sender as-is and add your mechanical gauge as a duplicate.
I just installed an Autometer water temp gauge recently. Read this it should help you out on what to do.
https://www.ford-trucks.com/forums/s...d.php?t=488849
Originally Posted by 81fordf-250
I have a parts truck and it has the sender in the heater hose area. It was at the front of the engine. It still had the factory temp guage hooked up.There was a extra port there but I don't know how accuret it would be in this location may read a little cool.
Yes. The EFI 4.9 has the same temp sensor that the carb engine does. It sits just below and behind the rear most exhaust port on the passenger side. This is for the dash gauge.
Then, there's a second sensor that is all the way up front, and (if I remember right) is mounted on the thermostat housing. This is the sensor for the fuel computer.
Nathan Cox
08-08-2016 02:24 PM
1982fordf100
16
05-08-2006 08:11 AM
