vin numbers
vin numbers
after working on my truck for a couple of weeks i've noticed a lot of numbered tags here and there on it. such as dist clamp bolt, carb., rearend,door,and i think there is one on the transmission. can some one tell me where all the tags were on the truck when it was new? it's a 69 ranger. i'll gather all the numbers and post them. is it possiable it has all the orginal tags?
vin numbers
I think you've got most of them. There are also date codes printed on the windows, a tag on the seat back and a casting date cast into the engine block above the starter as well as on the heads. Some of the sheet metal is also date coded. The instrument cluster housing and radio often have dates stamped on them as well. On two 68's in the area here I have seen a final assembly date stamp on the firewall above the master cylinder.
vin numbers
>Dist.
>360 69 3
>9FK 304S
This tag says that you have a 360 and the dizzy is from 1969.
>Door
>F10 YC F93233
This is your Vin It also says that you have the 360.
>115 7 F100 2 81 C17
>05000 175 4000 21
These tell you different thing like gross vechile weight, transmisson, ect...
>Rearend
>W D H-S 9GB
>3.25 9 313B
This says that you have a ford 9" rear with 3.25 gears.
Hope this helps. I'm not 100% positve I got all of these right so if anyone wants to correct me please do.
vin numbers
Here's a little more info to add, sorry I don't have all that info on me right now.
Carb.
Autolite 2100 2V with IMCO exhaust emission, manual trans, for 360/390, venturi dia. 1.231", 352 cfm.
Dist.
That's actually the engine tag. '69 360, change level 3, assembled in June of '69.
Door
F100 4x2, 360 engine, built in Ontario
115" wheelbase, dark blue exterior paint, conventional 2 axle-gas, med. blue ladder & crush vinyl interior trim, 5000 lb. max GVW, 175 certified net hp @ 4000rpm.
Rearend
Sure that's a W D "H" and not a W D "M"? Anyway, it's a Ford 9" 3.25:1 non-locking.
Barry
Carb.
Dist.
Door
Rearend
Barry
