High Pinion D44
04-22-2006, 04:48 AM
on
High Pinion D44
I found a high pinion dana 44 with 4.09 gears and nice locking hubs with the big dayton brakes under a 78 bronco.
I can't find brake pads.
I dont think the axle is stock to the bronco. What could it be from?
-kit
04-22-2006, 06:58 AM
why dont you think it's stock?
04-22-2006, 11:16 AM
on
Sounds like the brake pads from a '78 f250 would probably fit nicely. My '78 F250 CC has dual piston Dayton calipers on a Dana 44 (Dana 44-9F) high pinion front end.
04-22-2006, 02:59 PM
on
Is it 8 lug or 5? If its 8 lug it probably has had dual piston calipers swapped on from a F-250.
04-23-2006, 12:02 AM
on
Quote:
It was on leaf springs. The entire front suspension seemed extremely home made. Probably why it ended up in a junk yard.
It is 8 lug with the dayton two piston calipers.
-kit
04-23-2006, 06:21 AM
It's a 3/4 ton axle set up so you need to ask for 3/4 ton 4x4 brake pads. Make sure its a D44 and not a D60. The D60 will need different pads, I think.
04-23-2006, 08:06 AM
Yea, I guess the leaves would kinda give it away huh? RTM and Tjay are right, sounds like you got the same axle I have under my 250.
04-24-2006, 07:28 PM
on
performance friction carbon mettalic #0450-20 at autozone
04-25-2006, 01:17 AM
on
04-25-2006, 12:42 PM
oh man, don't buy brake pads at Autozone.
Junk, junk, junk.
