Alternative fuels ?
Old 05-03-2006, 04:25 PM
jarmeister's Avatar
jarmeister
jarmeister is offline
Alternative fuels ?
What's needed to add/convert to CNG?
Old 05-03-2006, 04:56 PM
Bdox's Avatar
Bdox
Bdox is offline
Check the alternative fuels forum.
Also, most gas suppliers can steer you to the info.
Old 05-03-2006, 11:13 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Thread moved.
Old 05-04-2006, 10:29 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
EFI engines can run on CNG without major changes. The big expense is for high-pressure tanks, regulators and fittings, since CNG is dispensed at up to 3600psi. This differs drastically from LPG systems.
My brother has owned a CNG (factory) Crown Vic. Now he has a CNG Honda Civic. Both engines looked no different than the gasoline versions. CNG runs so clean that the tailpipe has no soot at all. It looks like the engine was never started.
Jim
Old 05-04-2006, 10:43 AM
fraso's Avatar
fraso
fraso is offline
I presume you want to convert your own vehicle (1976 F250?) to CNG dual fuel operation. I believe you will need the following items for this conversion:
  • dual fuel mixer (Impco Model 300?) & air cleaner
  • mixer to carburetor adapter
  • CNG pressure regulator
  • CNG storage tank(s)
  • CNG fill valve
  • CNG fuel lines
  • CNG pressure gauge
  • electric shut-off valve for gasoline
  • electric shut-off valve for CNG
  • electric switches for dual fuel operation
I think that's most of it. Since the storage capacity of typical CNG tanks is equivalent to a few gallons of gasoline, ideally you should have a CNG filling station on your normal route. If not, you might also want to consider PHILL.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Alternative fuels ?
