For people with smog, check your vacuum check valves.
Old 04-18-2006, 10:33 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Talking For people with smog, check your vacuum check valves.
I have been having problems with my EGR valve for several weeks. Had to replace it cause it was defective. Living in california and their smog rules etc...
Well, the truck started to run like crap again. Thought I had that fixed, but it was just the old EGR going bad I guess.
Anyway did some looking at the system, and there is a vacuum check valve on the line that goes to the EGR valve, from another vacumm source, besides the ported vacuum on the carb. A little tiny thing plugged inside the vacuum line. It was letting vacuum through both ways. It's not supposed to do that. Since the check valve was bad, it was letting too much vacuum to the EGR and causing the truck to run crappy.
The Part is called a Vacuume hose check valve, part # on the valve was a D9AE-AA it was Blue and black. This valve is used from 1979 to 1995.
This valve is also used for distributor, EGR and other vacuum assisted devices.
If you have been having problems with your truck and you can't tell what's wrong or where the problem lies, don't overlook the small things like that vacuum check valve, if you have one.
Thought I'd let you guys know.
Old 05-07-2006, 11:03 AM
amish77's Avatar
amish77
amish77 is offline
sounds like a plan. Cacuum is one of those things that's easy to forget. I replaced all my hoses (I think) when I bought the truck.
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
HoustonDave
13
01-09-2018 06:30 PM
Ar. Hillbilly
11-03-2016 08:12 PM
cberr
1997 - 2003 F150
21
02-22-2016 07:02 PM
jonmark1985
06-25-2013 05:53 PM
Quick Reply: For people with smog, check your vacuum check valves.
