AC Low Side Pressure TOO High...
Old 05-07-2006, 08:08 PM
boxcar_tommie22's Avatar
boxcar_tommie22
boxcar_tommie22 is offline
the outside temp is 71
Old 05-07-2006, 08:13 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
If the engine is warm then pressures will be higher. The static pressure shouldn't concern you. Whats it do when the compressor comes on?
Dick
Old 05-07-2006, 08:25 PM
boxcar_tommie22
cycles on and off then stays on. the air is nice and cold..when i hook up a psi press. meter on the low side it says 25 psi and i can add a whole can in there and it still doesn't move
Old 05-07-2006, 08:29 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Its not supposed to if its already full.You have to be carefull not to over full. Check the big line into the compressor if it gets cold then the system is full. I would be carefull not to over fill the system. Those pressures sound like its running good. Any other concerns?
Old 05-07-2006, 10:35 PM
motorcyclist's Avatar
motorcyclist
motorcyclist is offline
to do it right, you need to recover all the gas in it, pull a good vacuum, then weigh in the amount as specified by the mfg.
guess charging a small system is tricky.
Bill
Old 05-07-2006, 10:45 PM
Fireferg73's Avatar
Fireferg73
Fireferg73 is offline
When you test the vent temps, what should the fan speed be? Mine seems to work great on the first two speeds, but doesn't get as cold on the third or fourth setting. It will get down to 44-47* on the lower speeds and only 53-58* on the higher two speeds. Ambient temps between 85-95*
SA told me recently that Ford's specs for A/C performance was fan speed on lowest setting(don't know if this is true.)
My whole A/C system is basically new, new compressor/accumulator/orofice tube/various other hoses, o-rings, ect... Courtesy of Ford(warranty) I will occasionally see vent temps of 60* with Max A/C and fan on high.
I'm not sure if it's working properly or if something is still wrong. I know it's a big cabin, but it doesn't get nearly as cold inside as the wifey's Maxima.
Thanks for the help,
Jay
Old 05-07-2006, 11:00 PM
G'sRed99F150's Avatar
G'sRed99F150
G'sRed99F150 is offline
The more air the fan pushes across the coil, the amount of the heat exchanged increases, making the air warmer out of the vents. The slower the air moves, less heat exchanged, causing cooler temps.I would say your A/C is working normally.When you see the temps ocassionally at 60, the compressor could be cycled off at that time, you should see the temps drop back down.
Old 05-08-2006, 11:30 AM
boxcar_tommie22
thanks you guys!! for all your help
Old 05-08-2006, 01:09 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
That what weez hea 4..
Dick
Cbx1013
07-24-2017 09:41 AM
monkeyWrencher
1997 - 2003 F150
07-11-2011 09:36 PM
tonyrcl
1997-2006 Expedition & Navigator
07-26-2009 03:05 PM
rangerang
1983 - 2012 Ranger & B-Series
03-28-2006 10:21 PM
pikiluvi
05-17-2003 12:35 AM
Quick Reply: AC Low Side Pressure TOO High...
