33x12.5x15S rub hard in front.
You'd need a 4" lift for those to fit comfortably since it's a 2wd.
2x4 is a piece of wood, you've got a 4x2
The 4wd springs are pretty much the same if not identical to the 2wd springs. The reason for the 4wd being 2" taller than a 2wd, is because of the TTB 4wd axle. It makes the truck sit 2" higher, and the truck has 2" more lift on the rear axle to match.
nskitts
08-19-2007 12:26 AM
