Helppp!!!!
I agree with 312; I think you'll be happier with the carb. You have a lot more tuning options without having to worry about changing chips and sensors and running miles of wire. Any good performance parts supplier should be able to provide a good carb and intake that will be bolt on; such as summit or jeg's. Or for that matter,I believe an '86 5.0 4 barrel intake should be a bolt on,but I'm not positive. Electric pump is a must but you can buy a pump for a carb application, so you may not need a seperate regulator. Hope this was hlepful.
I believe the EFI blocks just had a plate where the mechanical fuel pump went, you'll still need a camshaft eccentric to make it work... the mechanical pump is a lot more reliable and way cheaper to replace than the electrics...
I would go with a carb in your situation, since your truck was built for a carbureted motor, meaning the holes in the firewall are just big enough for the minimal wiring harness, no bracketry for TV cables to build, blah blah blah...
dwrestle
03-02-2012 11:55 PM
Whiskers
06-05-2001 08:56 AM
