Iowa Chapter Join Chapter, Leader:
Another Truck
Old 03-22-2006, 02:56 PM
69 and 85's Avatar
69 and 85
69 and 85 is offline
Another Truck
Here's my latest find.
85 F150 Extended Cab with 351 HO /C6. After a quick "once over" the body is good - cab corners, rockers, fender, doors, tailgate.... just the box has the typical rust over the wheel well.
It has A/C, cruise, class III hitch and trailerbrake control.
I figure it's going to be a pig on gas, but the price was right and I don't have any trucks that would really handle a trailer. I'll probably look into upgrading the rear springs and maybe getting a rust free box for it. Of course, my dreams and plans change all the time depending on what I have bought lately : )
I guess this means I will be selling off parts to have cash on hand for the next deal!
Old 03-22-2006, 06:47 PM
fellro86's Avatar
fellro86
fellro86 is offline
always something... I quit buying things most of the time because I would run out of space to park them,,, that's pretty sad with a 200 acre farm...
Old 03-23-2006, 10:04 AM
69 and 85's Avatar
69 and 85
I got the truck home lastnight and out in the open so I can look at it. Turns out it already has helper springs and sway bars. The shocks aren't even rusty, so I got on each bumper corner and this is one stiff pig. Should be able to haul a load or pull OK with that suspension and long body. 235 tires and matching spare are all good too. I still have new 16" tires on my bus that would work well too if I had 16" 5x5 rims.
I didn't see an aux tranny cooler tho... I wonder if the '85 factory tow package would have had a tranny cooler? Atleast the radiator is near new. Installed last year with a manufacturer sticker of '03.
Interior could use help - It's tan and the door panels would look a lot better if I painted them. If there somewhere in DM that sells color matched paint that'd work well? -thx
Old 03-23-2006, 05:09 PM
Flareside94's Avatar
Flareside94
Flareside94 is offline
Nice find, sounds good!
Old 03-23-2006, 05:36 PM
fellro86's Avatar
fellro86
fellro86 is offline
You could check with Eastwood, they have a lot of the special paints like that, www.eastwoodco.com, or maybe check with a local Ford dealer to see if they might have something, back when I was working for the dealers, the replacement parts all came in the same color, and we had to paint them to match.
Old 03-23-2006, 11:52 PM
69 and 85's Avatar
69 and 85
thx - will check Eastwood in a minute. I found the tranny cooler - just not where I expected it was high infront of the A.c cooler. I was cleaning it up and found the bed to be better thatn I thought. I was able to reach in and knock the biggest dents out pretty good. We'll see if the bed psses the testes!
Old 03-24-2006, 05:53 AM
69 and 85's Avatar
69 and 85
OWWW! I meant passes the "tests". I have a couple of family members that are pretty picky about what they will drive and not everyone appreciates all my "good trucks".
Old 03-24-2006, 06:37 AM
fellro86's Avatar
fellro86
fellro86 is offline
Are you sure you didn't have it right the first time? I know what you mean about not everone in the household liking your wheels... I can put up with a lot less than perfect, while others are embarrassed to do so... I do have my limits though.
Old 04-05-2006, 12:16 PM
BigBear1's Avatar
BigBear1
BigBear1 is offline
Sounds like a good truck. If you ever want to sell the bed and tailgate I'm still in the market for a good one.
Old 04-10-2006, 08:02 AM
69 and 85's Avatar
69 and 85
I knew it needed at least a timing chain, but when I got to the cover I could see it was torn up. I pulled the cover and discovered that the strong dbl roller chain had jump and whipped around, bent the end of the cam and popped the retainer and broke a chunk of the block out.
Yesterday I pulled the engine and found 2 nice holes in the oil pan... I didn't know it had thrown rods because they were hidden by the cross member. LOL. Had I seen the holes, I wouldn't have wasted time on the timing chain.
The tailgate is excellent, but the bed is junk. Typical wheel well and rear corner rot- not to mention they creased it a good one!
Old 04-10-2006, 08:17 AM
fellro86's Avatar
fellro86
fellro86 is offline
as long as the price was good enough to not be a problem.. kind of like the 79 I had, they knew the engine had trouble, I pulled the timing cover on it, everything looked fine, but in tryin to turn it over, the front of the crank moved... I gradbbed hold, and realized it had a broken crank, the first I had seen in person. That was a 400... But I bought the truck right, and since I had my 86, didn't need it , so I sold it for more than I bought it for...
Old 04-10-2006, 08:27 AM
69 and 85's Avatar
69 and 85
I did get a good price. The cab and front clip are practically rust free - even underneath. The doors have a surface spots that could probably be fixed with rubbing compound and a tiny dab of touchup paint. The hood is pretty weathered, but no rust.
No problem to put in another engine and have a good (and cheap) truck.
