Where are the fusible links for the glow plugs?
I have a 2002 Excursion 7.3 diesel. Check engine light came on. Scanner says cylinders 2,4,6,8 glow plugs not working. I think it's the fuse for that bank of plugs. I can't find it. Manual says there is a fusible link, for each bank of plugs, in the wiring harness that leads to the glow plug circuit but nothing else more specific. Can someone please tell me where to look?
Mike
Mike
i have never seen or head anything that refers to a fusible link in the glow plug system. your X has a glow plug module that monitors the current to each bank of glow plugs. if one or both of the banks shows a lower than normal current it will set a code and direct you to the bank with the low current. i would say you have one or more bad glow plugs on that side.
check this out:http://www.streamload.com/nlemerise/Ford/gpr.pdf
HELP - Hey I have the same issue - WHERE was that loose connection?!
Help me out here,
Where was that loose connection - I have the 2,4,6,8 glow plug circuit error, and the Fusible Link (Yes, there is one for each side) does not seem to be the problem. I'm looking for a loose / lost connection somewhere and haven't found it yet. It is doubtful that 4 glow plugs failed at the same time.
Please advise - ideas welcome.
Thanks!
Thanks!
Originally Posted by FordManTim
Help me out here,
Thanks!
Thanks!
Help me out here,
Please advise - ideas welcome. Thanks!
i would guess the lose connection he is talking about is the VC (valve cover) plug. it is on the top middle of each valve cover
Thanks for the input - I've checked and re-checked that connector on the head- will keep searching and let you know.
Regarding the fusible link(s), they are on all non-CA motors on the GPR, at least in the Excursions....I would not have found it except for a reference in the Haynes manual.
Regarding errors, I am getting 4 separate error codes: one for each individual glow plug. The quick response from the parts store was to sell me 4 glow plugs, however, I'd heard a few people finding loose / missing connectors,etc.
Here are the errors specifically that I am getting:
P0672,P0674,P0676,P0678
On my previous daily driver - '97 Ford Expedition, I did get the code errors for the entire 'bank', and not cylinder by cylinder..
it's nice that the 7.3l will actually (hypothetically) display an individual GP circuit fault, helping to diagnose it directly.
In any case - thanks to all for the input - I'll post the solution when I find it, and appreciate all further ideas / experience, etc.
next up - pulling the valve cover and checking the connections at the GPs and internal connector. . .
Hmm, I'm sure someone else will chime in but I just can't see a whole bank failing all at once. You can check the circuit at the GPR and then the harness with a meter to at least verify the need to pull the valve cover. Is it starting OK? If so, have the trouble codes reset after verifying the juice at the valve cover connector and GPR. See if it returns.
On edit: as for the fusible links, I don't have/know about them. Run a jumper of sufficient gauge and bypass it, after resetting the codes and see if it returns.
Originally Posted by amiller93
It is in the harness Near the GPR there are 2 12ga gray wires. PM me your email and I can send you the schematic. It doesnt locate them avery well but will get you in the area and let you know what to look for.
