1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
f450 GVWR
Old 03-16-2006, 03:35 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
f450 GVWR
Whats the highest GVWR a 99-05 f450 can have?
I know the F-550's have either a 17.5k or 19k GVWR.
Old 03-16-2006, 04:57 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
If your talkin dually -16,000
For a 05
Rich
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
do you mean GCWR?
Old 03-16-2006, 04:59 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
no.............Gross vehicle weight Rating (I gotta figure out payload)
Old 03-16-2006, 05:00 PM
ford390gashog
ok just checking.
ford lists the 450 @ 16,000 lbs
and the 550 starts at 17,950
Old 03-16-2006, 05:05 PM
FortyFords's Avatar
FortyFords
Jake go here fleet.ford.com/truckbbas/
You know to put www.in front of that.
Rich
I don't write them that way because they get erased otherwise
Old 03-16-2006, 05:09 PM
ford390gashog
Rich,
that has been fixed on FTE. You can now type it out www.fleet.ford.com/truckbbas
Old 03-16-2006, 05:20 PM
FortyFords's Avatar
FortyFords
Thanks gashog !
Jake did you find what you were looking for?
Rich
Old 03-16-2006, 11:56 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
yyea, I want a 550 with a 16 foot flat bed that weighs 5k lbs...lol
Old 03-17-2006, 01:02 AM
ford390gashog
wow that leaves little payload. the 550 at work weighs 8900 pounds. we put a 16' aluminum rollback on it which was 2200 lbs. leaves us 6850 lbs of load capacity.
Old 03-17-2006, 06:23 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
Whast I meant was I want the whole truck to weigh 5k lbs, I need a huge payload
SD2
2017+ Super Duty
04-27-2017 01:37 PM
AsTheSun
12-15-2016 09:51 AM
2009kr
2017+ Super Duty
43
11-01-2016 01:30 PM
Louisiana Swamp Man
Fifth Wheel & Gooseneck RV Towing
07-18-2016 07:44 PM
Tuxedo Scorpion
6.7L Power Stroke Diesel
42
03-11-2016 05:17 PM
Quick Reply: f450 GVWR
