Key "on" source for +12V
I'm not sure about the 2005's but the older ones (eg 2003) have a "customer access" wire on fuse # 29 which is a 10 Amp circuit. Locate your OBD II plug under the dash and follow it's wire bundle up towards the radio. You should have a white with blue tracer wire which is capped off with a black heat-shrink piece and that is taped to this wire bundle. Power is on in "RUN" only.
on
The 2005 and 2006's have the same customer access wire.
Here's a pic:
http://www.pbase.com/image/57277770.jpg
Here's a pic:
on
Originally Posted by skinner00
any idea for a 20 amp circuit? (for an air horn)
I thought this was exactly what I needed, but either I didn't find the right wire, or it isn't quite what I'm looking for. I found a white wire with a blue trace, in what I think was the right location (behind the "ash tray"). It was a stub, and it only comes on when the key is in "run". However, the voltage isn't constant. It seems to increase with engine temperature, although I can't be sure of that. Seems like the voltage starts around 11.5V, gradually increases, then tops out around 13.9V.
I guess for many applications this would be fine. I need the power for my radar detector, however, and that seems to be voltage sensitive. Below about 12.? V, it behaves crazy. I could almost live with it, since the whacky behavior only lasts a few minutes (or less?), except part of the whacky behavior is incessant chirping. Drives me nuts.
Anyways, did I find the right wire, and this is what it does? Or did I find a different wire?
thanks,
-robert
thanks,
-robert
Thanks for the offer. I have factory upfitter switches, and that was what I was planning to use originally. Researching how to tap into them I came upon this thread, and thought this was and even better deal - on only when the key was turned to "run". I guess I'll go back to the upfitter switches.
What do you mean "make the switch momentary"?
thanks,
-robert
thanks,
-robert
Originally Posted by richsoucie
ohh and are you sure that the wire you tested goes up with engine temp and not engine speed cause some of the trucks have speed sensitive cd players
My radio/CD has an adjustment to get louder as the cabin noise gets louder. I think that goes up with ambient noise, though, not engine speed.
