Timing; Gear Vs. Chain
If you are spending the money to rebuild an engine, go with a good set of double roller timing chains & gears. Hardened & prestretched are the best. I usually use timing sets from the same company that I get the cams from (ie. Comp, Crane, etc.)
Now if you are building a race/high performance engine, gears are only way to go. More timing options, (degrees of advance or retard). And with gears and you don't have to worry about high RPM's, fast rev.'s, or high temps. stretching the chain. But they do make noise.
I ran an Edelbrock gear drive on a previously owned and built F-150, no problems whatsoever. I put over 50k on that motor, had all crane roller valvetrain, headders and 4bbl. I drove it year round. The gears made a lot more noise at -20F than it did at +80F. Motor pulled real hard all the way to 6k. Not sure I buy the 10hp power loss due to friction. It seems like there would be less friction ...
[QUOTE=Blurry94]Me personally, for a daily driver, I'd stick with a good double roller timing set. The gears transmit unwanted harmonics/vibrations between the cam and crank.[/QUOTE
Waaay back when, Honda motorcycles went from gear drive back to chain or belt on the V4 race motors for the exact reasons stated above.
I understand that was for motors that pulled double (or more) the RPM's a V8 would pull but I'd bet the same principles apply.
there are chain sets out there that have much more timing adjustability than gear, ex. the cloyes hex ajust, double true roller, and you can adjust anywhere from 6 deg adv. to 6 deg ret., also has the 3 keyway sproket.actually around here, i seen a lot of the big dogs running dry belt systems, way better timing they say. not very good for street use though.
