MAF cleaning
I carefully use a q-tip and isopropyl alcohol. Some of the spray cleaners contain ingredients not good for the sensor. Aerosol cans have a static electricity output of around 5k volts. The computer and other sensors might not like this if it gets back to it. So make sure it is unplugged if you do use the spray. jim d
crc makes something specially for this issue. Its called Crc mass airflow cleaner. Go figure... It works great i was having problems with my maf however it was on my wifes celica. It took care of the problem and about 70$ too. I believe it only costs 5$ or so for it. I found mine at pepboys . I tried looking everywhere discount autozone napa, and this is the only place i found it. Some of these stores might carry it in your location . Crc electrical cleaner works great too. Just make sure when cleaning this fragile parts its disconnected from a power source.
A couple of comments on this:
The MAF in my 4.6L's and my V10 get dirty in 20K miles. Enough so, that each time I clean them, they run better, shift better, etc.
Now, as to Ford's MAF that they have been using since at least 1996.
The wires on this MAF are pretty solid - the thin wires are wound around what appears to be a glass bead, and then coated in more glass.
No matter what chemical you use, you won't hurt the filaments (wires) on the MAF - you MIGHT ruin the O-ring, if you leave it on the sensor when you clean it, or the plastic base. I've used electrical cleaner, isopropyl alcohol, but brake cleaner works the best. And won't harm anything...
WARNING with BRAKE CLEANER: DO NOT spray it into the intake and let the engine burn it off. The results of burning that stuff is something akin to mustard gas - as in it really is a foul, probably lethal, gas after it's burned.
