Arkansas Chapter Join Chapter Leader: Kramercd
Sanding
Old 03-15-2006, 06:30 PM
Ozark Ford_1970's Avatar
Ozark Ford_1970
Ozark Ford_1970 is offline
Sanding
Any one have an idea about the cost of having my 1970 F-100, long bed either sand blasted or sanded. The paint that is on there now is terrible.
Old 03-15-2006, 07:02 PM
cookie88's Avatar
cookie88
cookie88 is offline
It would depend on the body man's rates. I don't really know what they make, but 10 years ago the premium body guys were getting $100/hr. or better. I would imagine the prep work of stripping the old stuff would be a good bit less than that since the paint guy would farm that out to the hired help.
Old 03-15-2006, 08:54 PM
jimkidd's Avatar
jimkidd
jimkidd is offline
If you had an air compressor you could rent a sand blaster and DIY
jimbo
Old 03-16-2006, 12:59 AM
Ozark Ford_1970
Ya' I have to figure out how I am going to get this paint off.
Thanks for the reply.
Larry
Old 03-16-2006, 11:12 AM
bhodgin's Avatar
bhodgin
bhodgin is offline
Sand blasting creates pits and I would not recommend that but my cousin has a chevy he had bead blasted for a couple hundred dollars in NW Ark
Old 03-16-2006, 02:53 PM
Ozark Ford_1970
Do you know the name of this place?
Old 03-16-2006, 03:09 PM
1996pwrstrk's Avatar
1996pwrstrk
1996pwrstrk is offline
If you are going to have the complete body done I would suggest media blasting because sand ,even bead blasting ,creates heat that will distort your sheet metal. The media blasting uses plastic or sometimes crushed walnut shells and doesn't heat up. I don't know of any place to get this done here but I will ask around.
Dave
Old 03-16-2006, 03:17 PM
Ozark Ford_1970
Dave
Thanks Dave.
Larry
Old 03-17-2006, 06:26 PM
bhodgin's Avatar
bhodgin
bhodgin is offline
he said there was a place called waynes sandblasting that did it in springdale but isnt sure if its still around
Old 03-17-2006, 06:30 PM
Ozark Ford_1970
Thanks. I will check. I am only about two hours away from there.
Larry
Old 04-03-2006, 03:06 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Yes, sandblasting will distort metal, and it will also find every thin spot of metal on the truck also (I really don't want to tell how I know)
Jeff
Old 04-03-2006, 09:17 PM
Ozark Ford_1970
Lightbulb Thanks Jeff:
Jeff
Thanks for the heads up Jeff. Bet I can guess how you know!
jevanof
Michigan Chapter
13
09-19-2013 10:07 AM
schoo
Paint & Bodywork
03-14-2013 08:04 AM
abe
01-22-2013 02:14 PM
bigern26
09-14-2010 09:41 PM
dagwood41
Michigan Chapter
06-12-2003 06:43 PM
Quick Reply: Sanding
