'78 3 speed manual - what is it and what gear ratio?
1978 F150 2wd with 302
What model is the 3 speed manual transmission? And what are it's gear ratios? The transmission code on the door tag is "C".
Edit: Oops, I meant to post this in the transmission forum...
I tried to find his thread, no luck.
Are you trying to rebuild a Ford 3.03 3 speed?
There are parts available for some if not all.
Look for a tag or a number cast into the case. Look for letters like "HEH", "HEG", "RAT", "RAN" and post all the numbers you find.
RAT rebuild kit
I found this rebuild kit:
https://shop.broncograveyard.com/RAT...uctinfo/11010/
Edit: added another:
https://picclick.com/RAT-RAN-RAB-HEF...496850878.html
Sorry it's been a while.
I have removed my driveshaft,
disconnected the bracket on the crossbeam (long bolt and nut),
disconnected the speedo cable,
disconnected the shift levers,
and removed the 4 bolts holding the gearbox to the
bell housing, but re-tightened in the top 2 bolts to hold
the trans in place until I figure out how to secure and pull the trans.
Do I need to remove the crossbeam under the trans before I remove trans?
