put in some new seals BEFORE you install it, their cheap, but you'll need a good air wratchet and a puller to put em in,
I found a decent one for $75 , it still going good
If you are looking for a power steering gear box at the wrecking yard what things should you look for? Is it possible to feel play in the shaft? How can you tell if it is going to be worth your time to install?
Thanks,
Terry
If I were you I would stay away from the 78-79 gear boxes ford stoped using the Saginaw(I think i'm not sure) boxes and started making their own that liked to blow seals and wernt all that great. But if you are talking just the power steering pumps the 78-79 are better than the 77 when I do my motor change im going to go with one.
I have got a 1979 4wd w/ps and a 65 2wd with a 77 p/s box on it and i have never had any problems with the seals.Both have close to 200,000 miles on them
