99 F150 4x4 4.6l cel
For the P1450, start here: https://www.ford-trucks.com/forums/s...ighlight=p1450
The P0401 has about a million posts. It is usually either a DPFE sensor or clogged EGR ports. SEARCH for these keywords: "P0401 DPFE EGR Vacuum" or just look around for more than 30 seconds.
Steve
Steve
i had seen some threads on the p0401 code but not with the p1450 with it. Thought maybe somebody had these codes together and had an idea. I had read about replacing the egr and cleaning but i also have the p1450 code which is evaporative emissions control system and thought maybe one might be causing the other. Basically was wondering if i should focus on one code or the other if one was possible causing the other. Would be cheaper to fix. Not as familiar yet with newer systems as i have mostly owned pre-85 stuff. Mainly 50's and 60's. Really like these 99-03 trucks though. Anyway, thanks for the reply.
