You are good with a non-vented cap, if there's a line down the passenger side of the gas tank going to a charcoal canister that is mounted to the right frame rail, near the radiator.
On replacement caps for the 68 and 69 I went in from the bottom with a hot needle, burned a pin hole to prevent expansion pressure ballooning the tank.
.....=o&o>.....
