Air suspension Switch on 2000 Expedition?
Hi Chevy! The switch is just an on/off and is located on the kick panel on the passenger side under the dash. It is Red and should be turned off any time the truch\k is jacked up or put on a lift. The other switch you may be thinking of is the one that changes from All Wheel Drive, 4x4 HI and 4x4 Low. It is on the dash near the climate control. If you put the truck into 4x4 low the suspension will rise up about two inches higher than in the other modes.
The only other way to adjust the suspension is underneath the truck on the axle and that is a whole other story. Hope this helps.
makuloco2000
1997-2006 Expedition & Navigator
02-09-2016 12:34 PM
husky390
07-06-2015 08:09 AM
expeditionph
10-10-2013 09:39 PM
makthenif
11-21-2011 02:48 PM
