y block exhaust question
There is an exhaust gas control valve shown in the Ford Truck Manual that is installed between the crossover pipe and the rh manifold. Some pictures of stock exhaust setups that I've seen of other members trucks do not all show this part. Some photos show that the crossover is bolted directly to the rh manifold.
I'd like to know what this part does and why it is apparently optional?
Thanks,
Doug
Thanks,
Doug
Yep, that is what it is for, I think my gallery pic of my y-block catches a glimpse of the one on my y-block(sorry, just looked and the top radiator hose covers it up, but it's just a valve that inserts between the manifold and crossover pipe), well, it isn't going to be my y-block any longer, but yeah, you get the point.
It is called a heat riser and like the guys just wrote it is closed until the engine warms up. It is a bi-metal spring. It forces the air from the exhaust on the left side up over the intake manifold to heat things up faster for smoother running. By "optional" do you mean was it an option from the factory? No. It was standard on all V-8's. Is it optional to keep it on or not? Yes, I guess so. The engine still runs with it off.
abe
abe
In certain conditions the carburator can ice up causing very rough running when cold or maybe not run at all. You need high humidity and cold weather to create such conditions. Later enginers had hoses going to the air cleaners that came from the exhaust pipes to heat the air to prevent the icing,
Originally Posted by azwafree
thanks guys...I guess I won't need it in Arizona
abe
doylerochester
08-25-2013 06:22 PM
jimcar-9
01-05-2013 07:28 AM
bryan_johnson
03-01-2005 06:16 PM
