400m vacuum problem
400m vacuum problem
i just put a new Edlebrock aluminum egr manifold on my 400m and a new street avenger carb on it. hooked everything up, made sure the electric choke worked good, set the timing and started it and let it run for a little bit. it seems to studder alot, i rev the engine and there is like a pause then it revs up. i put it into drive and it starts to want to die and when i give it gas it wants to die even more, but went i start down the road its fine. pull up to a stop sign and it wants to die again, ther i have to put it into neutral to stop from killing it. oh i also put a new blaster 2 coil on it if that helps solve the problem. im open to any suggestions. im leaning more towards the vacuum leak and if so how do i find it.
jburroughs12
201
06-01-2011 08:07 AM
cj96f150
19
11-17-2008 02:15 PM
Hellbore
05-23-2006 05:22 PM
jimbo81587
04-29-2004 07:59 AM
