Compression test setup..
Old Jun 14, 2001 | 09:20 PM
tetraruby's Avatar
tetraruby
I bought a compression gage and hose today. I've been wondering what kind of condition my 300-6 in my '79 F100 is in. The directions indicate to: "disconnect the ignition's electricity at the distributer, ignition coil, or the distributer cap. The distributer's high tension lead should be grounded if it is diconnected." What does this mean? I assume I should remove the clip on the coil, but what about this grounding and is there anything special I should do to the ignition box? I just don't want to ZAP anything incedently. It also mentions to open up the throttle plates all the way. What's a good compression reading on a 300-6 with X80K miles on it?
Old Jun 14, 2001 | 09:38 PM
whomrig's Avatar
whomrig
[font size="1" color="#FF0000"]LAST EDITED ON 14-Jun-01 AT 10:40 PM (EST)[/font][p]Hi, if you have a hand-held remote starter tool, just clip one wire to the small terminal on the solenoid, and the other to the starter cable, then you dont need to disconnect anything. The instructions say that about disconnecting things because most guys would use the key to do this test. As for the compression reading, I would think of the 150lb ballpark (give or take) if it is running well. Most parts places should sell these remote starter tools if you don't have one.
Wayne
e-mail
http://home.pacbell.net/whomrig
Old Jun 14, 2001 | 10:56 PM
dave186's Avatar
dave186
You are thinking of disconnecting the coil + and - wires, they mean high tension, which means the high voltage wire going to the distributor. If you dont ground it and use the key, it will spark everywhere, if its not close enough to metal to spark ive heard its not good for the coil. So if you go that route, just hook it to a bolt or something so its grounded out.
Dave
http://www.davesmonsterpit.com/dmp31.gif
Old Jun 15, 2001 | 10:27 AM
beartracks's Avatar
beartracks
It's a good idea to remove "all" the plugs while doing the test. In conjuction with proping the throttle open it gives the most accurate readings.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jun 15, 2001 | 01:24 PM
Franklin2's Avatar
Franklin2
Yes, the engine will crank too slowly with the plugs in to give an accurate reading. I would warm the engine too and make sure you have a good battery. Propping the throttle open gives the cylinders plenty of air to suck in and compress to give you a good reading.
Old Jun 17, 2001 | 02:08 PM
tetraruby's Avatar
tetraruby
I bought a remote starter to add to my arsenal of tools..now how to use it. I'm getting different information. The first post stated to connect one clip to the small post (which one?) and the other to the engine starter post. The directions that came with the remote starter state to connect one side to the battery and the other to the "energized terminal on the solenoid." There's two small posts between the battery side and starter side. I assume these close the loop between the bat and starter via the ignition switch. So, what's the proper setup? I don't want to fry my solenoid or blow a fuse. Which of the two small posts is the energized one (the closest to the bat or starter)? Any experienced help is greatly appreciated. Happy Senior Ford Father's Day to those of you that have earned it
Old Jun 17, 2001 | 03:01 PM
whomrig's Avatar
whomrig
Hi, connect the starter to the small post closest to the big terminal and the big terminal (starter cable). This will be used in place of jumping the solenoid with a screwdriver.
e-mail me if you need to.
Wayne
e-mail
Old Jun 17, 2001 | 09:28 PM
tetraruby's Avatar
tetraruby
The working connection ended up being one clip on the (+) bat and the other on the small post closest to the battery. Anyways, now to interpret the data. I did everything as I was supposed to do except remove the air cleaner off the carb. My lowest reading was 160 psi and the highest was 180 psi. The average was 168. The difference appears good as well as the average value for my '79 300-6, right? It did take about five successive strokes in order to get the highest reading (on each). This indicates worn rings, right? If I had any cracks in the head or block would the compression test indicate it?
Old Jun 17, 2001 | 10:56 PM
Franklin2's Avatar
Franklin2
Sounds good to me. You have to judge what the compression guage is telling you with how the truck runs and it's overall condition. I would say you have good compression though.
Old Jun 18, 2001 | 04:09 AM
karljay's Avatar
karljay
I'd consider that to be very good. I like to watch the guage on the first stroke and see if it's making good comression on the first one but with 160~180 it sounds healthy.
Are you actually having a problem with the engine or are you just checking things out?
Old Jun 18, 2001 | 11:37 AM
tetraruby's Avatar
tetraruby
I'm just it out. I haven't had any engine problems at all. I bought the truck about a year and a half ago and I'm finally getting to the engine. Other than the fact that I have a number of gaskets and oil seals to change, the engine appears to be in good shape.
Old Jun 18, 2001 | 04:44 PM
tetraruby's Avatar
tetraruby
Each stroke was about 40psi (Including the first).
Old Jun 18, 2001 | 11:07 PM
dave186's Avatar
dave186
